pi@raspberrypi:~ $ cd /home/pi/mqtt-landroid-bridge
pi@raspberrypi:~/mqtt-landroid-bridge $ npm install
npm WARN notsup Unsupported engine for http-cookie-agent@4.0.2: wanted: {„node“:„>=14.18.0 <15.0.0 || >=16.0.0“} (current: {„node“:„14.17.5“,„npm“:„6.14.14“})
npm WARN notsup Not compatible with your version of node/npm: http-cookie-agent@4.0.2
npm WARN http-cookie-agent@4.0.2 requires a peer of tough-cookie@^4.0.0 but none is installed. You must install peer dependencies yourself.
npm WARN mqtt-landroid-bridge@1.0.5 No repository field.
added 21 packages from 31 contributors, removed 3 packages and audited 316 packages in 18.837s
21 packages are looking for funding
run npm fund for details
found 1 high severity vulnerability
run npm audit fix to fix them, or npm audit for details
habe Node V18.10 installiert, unter Windows, node bridge startet , zeigt dann aber einen Fehler:
npm install npm WARN skipping integrity check for git dependency ssh://git@github.com/iobroker-community-adapters/ioBroker.worx.git npm WARN deprecated har-validator@5.1.5: this library is no longer supported npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142 npm WARN deprecated circular-json@0.5.9: CircularJSON is in maintenance only, flatted is its successor. npm WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See There’s Math.random(), and then there’s Math.random() · V8 for details. npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
added 120 packages, and audited 121 packages in 11s
13 packages are looking for funding
run npm fund for details*
found 0 vulnerabilities
C:\Users\User\mqtt-landroid-bridge>node bridge.js Thu, 29 Sep 2022 14:37:57 GMT INFO: worx is selected Thu, 29 Sep 2022 14:37:57 GMT INFO: Connect to worx Thu, 29 Sep 2022 14:37:58 GMT INFO: Topic landroidmower sucessfully connected with local MQTT-Server Thu, 29 Sep 2022 14:37:58 GMT INFO: Login form loaded Thu, 29 Sep 2022 14:37:59 GMT INFO: Received Code Thu, 29 Sep 2022 14:38:01 GMT INFO: Connected to worx server Thu, 29 Sep 2022 14:38:01 GMT INFO: 1 Recieve User Devices Thu, 29 Sep 2022 14:38:01 GMT INFO: sucessfully connected with Mower (20203019930500101540) Thu, 29 Sep 2022 14:38:01 GMT INFO: Mower (20203019930500xxxxx) with Topic „landroidmower“ is online Thu, 29 Sep 2022 14:38:01 GMT INFO: Bridge for Mower (20203019930500xxxxxx) sucessfully established node:internal/tls/secure-context:279
context.loadPKCS12(toBuf(pfx));*
Error: unsupported
at configSecureContext (node:internal/tls/secure-context:279:15)*
at Object.createSecureContext (node:_tls_common:117:3)*
at Object.connect (node:_tls_wrap:1629:48)*
at Object.buildBuilder (C:\Users\User\mqtt-landroid-bridge\node_modules\mqtt\lib\connect\tls.js:20:26)*
at MqttClient.wrapper [as streamBuilder] (C:\Users\User\mqtt-landroid-bridge\node_modules\mqtt\lib\connect\index.js:155:36)*
at MqttClient._setupStream (C:\Users\User\mqtt-landroid-bridge\node_modules\mqtt\lib\client.js:415:22)*
at new MqttClient (C:\Users\User\mqtt-landroid-bridge\node_modules\mqtt\lib\client.js:395:8)*
at Object.connect (C:\Users\User\mqtt-landroid-bridge\node_modules\mqtt\lib\connect\index.js:157:18)*
at Worx._connectMqtt (C:\Users\User\mqtt-landroid-bridge\node_modules\iobroker.worx\lib\api.js:305:27)*
at Worx.start_mqtt (C:\Users\User\mqtt-landroid-bridge\node_modules\iobroker.worx\lib\api.js:283:18)*
at C:\Users\User\mqtt-landroid-bridge\bridge.js:141:16*
at Array.forEach ()*
at Worx. (C:\Users\User\mqtt-landroid-bridge\bridge.js:136:17)*
at Worx.emit (node:events:513:28)*
at C:\Users\User\mqtt-landroid-bridge\node_modules\iobroker.worx\lib\api.js:256:42*
at C:\Users\User\mqtt-landroid-bridge\node_modules\iobroker.worx\lib\api.js:253:38*
habe ich eben mal nachvollzogen. V18 funktioniert nicht. Aktuell läuft ausschließlich NodeJS V16.
Da musst du leider auf V16 zurückgehen. Dann läuft es auch.
Kannst du es nachstellen? Bisher hatte ich ja die Befürchtung das ich der Einzige bin den es betrifft, da die anderen ja eigentlich geschrieben haben das es dann mit Node 16 lief.
05.10.2022, 08:31:08 | FlowHandler | Kann Daten nicht zur Instanz #27786 weiterleiten:
Warning: Konnte Schaltpunkt mit ID 3 zum Löschen nicht finden in /mnt/data/symcon/modules/.store/silberstreifen.mqtt.worx/Scheduler/module.php on line 302
RESULT:
