I created a module, you can install it via the module control under core instances.
You will find the module soon via the module store.
Also you need at least Symcon Version 6.0 or higher.
You can control the smart lock, status updates are not included yet, but this will be our next step.
There is also no documentation at the moment, but I am sure you know what to do.
My next steps for you:
A manual status request should be possible:
Status. ATTENTION: you can only ask the status a few times per day, until you are rate limited
Can you check if you can get the right url and I need the result information of that.
So in your script maybe you have to replace „OPEN“ with „STATUS“, but I am not sure, var_dump is your friend for the result.
For the outgoing webhook (Loqed → Symcon) you need a valid Symacon subscription. Do you have one?
I had a good weekend, thanks! I hope you’ve had a good weekend too!
It also explains explains the late reply, I wasn’t at home.
Right now I have 2 working PHP scripts, one for the actions, created with your help, and one for the status updates, using the outgoing webhook. Maybe the script using the outgoing webhook gives you the needed information?
I will install the module right away!
Update: I’ve installed and tested the module. All commands are executed succesfully.
My idea is on the first creation of the instance we don‘t know the status of the lock.
So therefore we must get it manually.
For upcoming status events we could use the webhook for status updates.
I’'ve removed the API token and the Lock ID from the URL. „Lock ID“ is a new value, not yet defined in the module. „Device ID“ in the module is called „Lock ID (old)“ in the LOQED documentation.
I think we can confirm that the „status“ URL is different than the „command“ URL.
Status. ATTENTION: you can only ask the status a few times per day, until you are rate limited. Instead of asking for the status, you should implement a webhook that calls your server, so you are updated as soon as something changes, without polling. It returns the following JSON keys:
id (lock id)
bridge_online (1 if bridge is online, otherwise 0)
There is a new version online. Please update. I added the device states. In the instance configuration in the action area you will find a developer area and in this an update button for manual update.
Please let me know if this update button works. Before you press the button please open the debug for the instance to see further information and also the message tab.
I will add the outgoing webhook for automatic updates within the next days or next weekend, because my time is limited for today.
Thank you so much for your help. We need both the „Lock ID“ and the „Lock ID (old)“.
„Lock ID (old)“ is needed for the „command“ URL, „Lock ID“ is needed for the „status“ URL.
I just installed the updated module and will get back with the results.
I think the outgoing webhook is not updating the status. Is there a way I can test the outgoing webhook? The URL used in the module for the outgoing webhook looks a bit different than the URL I’m using for the outgoing webhook php script. It prepends username & password or something to the URL I’m using.
you have to use the web hook which was generated by the instance. It is displayed in the action area.
Please copy this and use it for the outgoing webhook on the Loqed portal for testing purpose.
You can test it using Postman, but you also have to use the generated webhook.
If you delete the instance, the webhook is also deleted. So if you create a new one, a new webhook will be created and you have to update it in the Loqed Portal.
Did the single update (update button in the action area) works?
The single update works as expected, the outgoing webhook doesn’t, I used the URL shown in the module.
The „old“ outgoing webhook PHP script still works. (It is possible to add multiple webhook URLs at the LOQED webhook service/portal)
