Hallo Zusammen,
ich bin noch recht frisch hier und habe mich gerade mal an das o. g. GUI gemacht, um es nutzen zu können.
Ich habe also einmalig und erstmalig das Baseloaderskript ausgeführt (IPS 3.0). Mit folgendem Ergebnis:
Download of ModuleManager
Load File https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/install/IPSInstaller/IPSInstaller.inc.php
Load File https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/install/IPSModuleManager/IPSModuleManager.class.php
Load File https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/install/IPSModuleManager/IPSVersionHandler/IPSVersionHandler.class.php
Load File https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/install/IPSModuleManager/IPSVersionHandler/IPSFileVersionHandler.class.php
Load File https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/install/IPSModuleManager/IPSScriptHandler/IPSScriptHandler.class.php
Load File https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/install/IPSModuleManager/IPSFileHandler/IPSFileHandler.class.php
Load File https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/install/IPSModuleManager/IPSLogHandler/IPSLogHandler.class.php
Load File https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/install/IPSModuleManager/IPSBackupHandler/IPSBackupHandler.class.php
Load File https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSConfigHandler/IPSConfigHandler.class.php
Load File https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSConfigHandler/IPSIniConfigHandler.class.php
Load File https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSUtils/IPSUtils.inc.php
Load File https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/config/KnownRepositories.ini
Load File https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/config/AvailableModules.ini
Load File https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/install/InstallationScripts/IPSModuleManager_Installation.ips.php
Load File https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/install/InitializationFiles/Default/IPSModuleManager.ini
Load File https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/install/DownloadListFiles/IPSModuleManager_FileList.ini
Create File __autoload.phpRegister IPSUtils.inc.php in File __autoload.phpInstallation of ModuleManager
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:03.91 Create Directory C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-17_0652\IPSLibrary\install\DownloadListFiles
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:03.93 Copy C:\IP-Symcon\scripts\IPSLibrary\install\DownloadListFiles\IPSModuleManager_FileList.ini --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-17_0652\IPSLibrary\install\DownloadListFiles\IPSModuleManager_FileList.ini
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:03.94 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/install/DownloadListFiles/IPSModuleManager_FileList.ini —> C:\IP-Symcon\scripts\IPSLibrary\install\DownloadListFiles\IPSModuleManager_FileList.ini
IPSModuleManager-Log-IPSFileVersionHandle2013-12-17 06:52:04.46 Set Version IPSModuleManager=2.50.18 (Loading)
IPSModuleManager-Log-IPSFileVersionHandle2013-12-17 06:52:04.46 Set Repository IPSModuleManager=https://raw.github.com/brownson/IPSLibrary/Development/
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:04.47 Create Directory C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-17_0652\IPSLibrary\install\InstallationScripts
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:04.57 Copy C:\IP-Symcon\scripts\IPSLibrary\install\InstallationScripts\IPSModuleManager_Installation.ips.php --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-17_0652\IPSLibrary\install\InstallationScripts\IPSModuleManager_Installation.ips.php
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:52:04.58 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\install\InstallationScripts\IPSModuleManager_Deinstallation.ips.php doesnt exists
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:04.58 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/install/InstallationScripts/IPSModuleManager_Installation.ips.php —> C:\IP-Symcon\scripts\IPSLibrary\install\InstallationScripts\IPSModuleManager_Installation.ips.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:05.39 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/install/InstallationScripts/IPSModuleManager_Deinstallation.ips.php —> C:\IP-Symcon\scripts\IPSLibrary\install\InstallationScripts\IPSModuleManager_Deinstallation.ips.php
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:52:06.19 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\install\InitializationFiles\Default\IPSModuleManager.ini doesnt exists
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:06.19 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/install/InitializationFiles/Default/IPSModuleManager.ini —> C:\IP-Symcon\scripts\IPSLibrary\install\InitializationFiles\Default\IPSModuleManager.ini
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:06.52 Create User File C:\IP-Symcon\scripts\IPSLibrary\install\InitializationFiles\IPSModuleManager.ini from Default File C:\IP-Symcon\scripts\IPSLibrary\install\InitializationFiles\Default\IPSModuleManager.ini
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:06.52 Copy C:\IP-Symcon\scripts\IPSLibrary\install\InitializationFiles\Default\IPSModuleManager.ini --> C:\IP-Symcon\scripts\IPSLibrary\install\InitializationFiles\IPSModuleManager.ini
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:52:06.53 Register Script IPSModuleManager.ini in Program.IPSLibrary.install.InitializationFiles (File=C:\IP-Symcon\scripts\IPSLibrary\install\InitializationFiles\IPSModuleManager.ini)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:06.53 Created Category Program=28199
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:06.53 Created Category IPSLibrary=36623
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:06.53 Created Category install=12088
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:06.53 Created Category InitializationFiles=39668
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:06.53 Created Script IPSModuleManager.ini=58439
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:06.53 Create Directory C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-17_0652\IPSLibrary\install\IPSInstaller
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:06.54 Copy C:\IP-Symcon\scripts\IPSLibrary\install\IPSInstaller\IPSInstaller.inc.php --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-17_0652\IPSLibrary\install\IPSInstaller\IPSInstaller.inc.php
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:52:06.54 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\install\BaseLoader\IPSLibrary_Migration.ips.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:52:06.54 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\install\BaseLoader\IPSLibrary_BaseLoader.ips.php doesnt exists
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:06.54 Create Directory C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-17_0652\IPSLibrary\install\IPSModuleManager
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:06.54 Copy C:\IP-Symcon\scripts\IPSLibrary\install\IPSModuleManager\IPSModuleManager.class.php --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-17_0652\IPSLibrary\install\IPSModuleManager\IPSModuleManager.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:06.54 Create Directory C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-17_0652\IPSLibrary\install\IPSModuleManager\IPSVersionHandler
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:06.55 Copy C:\IP-Symcon\scripts\IPSLibrary\install\IPSModuleManager\IPSVersionHandler\IPSVersionHandler.class.php --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-17_0652\IPSLibrary\install\IPSModuleManager\IPSVersionHandler\IPSVersionHandler.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:06.55 Copy C:\IP-Symcon\scripts\IPSLibrary\install\IPSModuleManager\IPSVersionHandler\IPSFileVersionHandler.class.php --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-17_0652\IPSLibrary\install\IPSModuleManager\IPSVersionHandler\IPSFileVersionHandler.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:06.55 Create Directory C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-17_0652\IPSLibrary\install\IPSModuleManager\IPSScriptHandler
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:06.55 Copy C:\IP-Symcon\scripts\IPSLibrary\install\IPSModuleManager\IPSScriptHandler\IPSScriptHandler.class.php --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-17_0652\IPSLibrary\install\IPSModuleManager\IPSScriptHandler\IPSScriptHandler.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:06.55 Create Directory C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-17_0652\IPSLibrary\install\IPSModuleManager\IPSFileHandler
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:06.56 Copy C:\IP-Symcon\scripts\IPSLibrary\install\IPSModuleManager\IPSFileHandler\IPSFileHandler.class.php --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-17_0652\IPSLibrary\install\IPSModuleManager\IPSFileHandler\IPSFileHandler.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:06.56 Create Directory C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-17_0652\IPSLibrary\install\IPSModuleManager\IPSBackupHandler
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:06.56 Copy C:\IP-Symcon\scripts\IPSLibrary\install\IPSModuleManager\IPSBackupHandler\IPSBackupHandler.class.php --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-17_0652\IPSLibrary\install\IPSModuleManager\IPSBackupHandler\IPSBackupHandler.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:06.57 Create Directory C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-17_0652\IPSLibrary\install\IPSModuleManager\IPSLogHandler
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:06.70 Copy C:\IP-Symcon\scripts\IPSLibrary\install\IPSModuleManager\IPSLogHandler\IPSLogHandler.class.php --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-17_0652\IPSLibrary\install\IPSModuleManager\IPSLogHandler\IPSLogHandler.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:06.70 Create Directory C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-17_0652\IPSLibrary\app\core\IPSConfigHandler
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:06.73 Copy C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSConfigHandler\IPSConfigHandler.class.php --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-17_0652\IPSLibrary\app\core\IPSConfigHandler\IPSConfigHandler.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:06.73 Copy C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSConfigHandler\IPSIniConfigHandler.class.php --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-17_0652\IPSLibrary\app\core\IPSConfigHandler\IPSIniConfigHandler.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:06.73 Create Directory C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-17_0652\IPSLibrary\app\core\IPSUtils
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:06.73 Copy C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSUtils\IPSUtils.inc.php --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-17_0652\IPSLibrary\app\core\IPSUtils\IPSUtils.inc.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:06.73 Create Directory C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-17_0652\IPSLibrary\config
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:06.74 Copy C:\IP-Symcon\scripts\IPSLibrary\config\AvailableModules.ini --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-17_0652\IPSLibrary\config\AvailableModules.ini
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:06.74 Copy C:\IP-Symcon\scripts\IPSLibrary\config\KnownRepositories.ini --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-17_0652\IPSLibrary\config\KnownRepositories.ini
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:06.74 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/install/IPSInstaller/IPSInstaller.inc.php —> C:\IP-Symcon\scripts\IPSLibrary\install\IPSInstaller\IPSInstaller.inc.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:07.69 Create Directory C:\IP-Symcon\scripts\IPSLibrary\install\BaseLoader
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:07.69 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/install/BaseLoader/IPSLibrary_Migration.ips.php —> C:\IP-Symcon\scripts\IPSLibrary\install\BaseLoader\IPSLibrary_Migration.ips.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:08.07 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/install/BaseLoader/IPSLibrary_BaseLoader.ips.php —> C:\IP-Symcon\scripts\IPSLibrary\install\BaseLoader\IPSLibrary_BaseLoader.ips.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:08.45 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/install/IPSModuleManager/IPSModuleManager.class.php —> C:\IP-Symcon\scripts\IPSLibrary\install\IPSModuleManager\IPSModuleManager.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:09.24 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/install/IPSModuleManager/IPSVersionHandler/IPSVersionHandler.class.php —> C:\IP-Symcon\scripts\IPSLibrary\install\IPSModuleManager\IPSVersionHandler\IPSVersionHandler.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:10.42 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/install/IPSModuleManager/IPSVersionHandler/IPSFileVersionHandler.class.php —> C:\IP-Symcon\scripts\IPSLibrary\install\IPSModuleManager\IPSVersionHandler\IPSFileVersionHandler.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:10.94 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/install/IPSModuleManager/IPSScriptHandler/IPSScriptHandler.class.php —> C:\IP-Symcon\scripts\IPSLibrary\install\IPSModuleManager\IPSScriptHandler\IPSScriptHandler.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:12.20 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/install/IPSModuleManager/IPSFileHandler/IPSFileHandler.class.php —> C:\IP-Symcon\scripts\IPSLibrary\install\IPSModuleManager\IPSFileHandler\IPSFileHandler.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:13.19 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/install/IPSModuleManager/IPSBackupHandler/IPSBackupHandler.class.php —> C:\IP-Symcon\scripts\IPSLibrary\install\IPSModuleManager\IPSBackupHandler\IPSBackupHandler.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:14.15 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/install/IPSModuleManager/IPSLogHandler/IPSLogHandler.class.php —> C:\IP-Symcon\scripts\IPSLibrary\install\IPSModuleManager\IPSLogHandler\IPSLogHandler.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:15.10 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSConfigHandler/IPSConfigHandler.class.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSConfigHandler\IPSConfigHandler.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:16.05 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSConfigHandler/IPSIniConfigHandler.class.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSConfigHandler\IPSIniConfigHandler.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:17.31 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSUtils/IPSUtils.inc.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSUtils\IPSUtils.inc.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:18.10 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/config/AvailableModules.ini —> C:\IP-Symcon\scripts\IPSLibrary\config\AvailableModules.ini
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:19.02 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/config/KnownRepositories.ini —> C:\IP-Symcon\scripts\IPSLibrary\config\KnownRepositories.ini
IPSModuleManager-Log-IPSFileVersionHandle2013-12-17 06:52:20.01 Set Version IPSModuleManager=2.50.18 (Loaded)
IPSModuleManager-Log-IPSFileVersionHandle2013-12-17 06:52:20.01 Set Version IPSModuleManager=2.50.4 (Installing)
File IPSWatering_Configuration.inc.php not exists (Namespace=IPSLibrary\config\modules\IPSWatering\Default)
File IPSWatering_Configuration.inc.php not exists (Namespace=IPSLibrary\config\modules\IPSWatering)
File IPSLogger_Configuration.inc.php not exists (Namespace=IPSLibrary\config\core\IPSLogger\Default)
File IPSLogger_Configuration.inc.php not exists (Namespace=IPSLibrary\config\core\IPSLogger)
File IPSMessageHandler_Configuration.inc.php not exists (Namespace=IPSLibrary\config\core\IPSMessageHandler\Default)
File IPSMessageHandler_Configuration.inc.php not exists (Namespace=IPSLibrary\config\core\IPSMessageHandler)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:20.03 Module Download Ini File doesnt exists -> Load Ini File „https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary\install\DownloadListFiles\IPSLogger_FileList.ini“
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:20.03 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/install/DownloadListFiles/IPSLogger_FileList.ini —> C:\IP-Symcon\scripts\IPSLibrary\install\DownloadListFiles\IPSLogger_FileList.ini
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:20.96 Module Ini File doesnt exists -> Load Default Ini File „C:\IP-Symcon\scripts\IPSLibrary\install\InitializationFiles\Default\IPSLogger.ini“
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:20.96 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/install/InitializationFiles/Default/IPSLogger.ini —> C:\IP-Symcon\scripts\IPSLibrary\install\InitializationFiles\Default\IPSLogger.ini
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:22.20 Create User File C:\IP-Symcon\scripts\IPSLibrary\install\InitializationFiles\IPSLogger.ini from Default File C:\IP-Symcon\scripts\IPSLibrary\install\InitializationFiles\Default\IPSLogger.ini
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:22.20 Copy C:\IP-Symcon\scripts\IPSLibrary\install\InitializationFiles\Default\IPSLogger.ini --> C:\IP-Symcon\scripts\IPSLibrary\install\InitializationFiles\IPSLogger.ini
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:22.21 Copy C:\IP-Symcon\scripts\IPSLibrary\install\DownloadListFiles\IPSLogger_FileList.ini --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-17_0652\IPSLibrary\install\DownloadListFiles\IPSLogger_FileList.ini
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:22.21 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/install/DownloadListFiles/IPSLogger_FileList.ini —> C:\IP-Symcon\scripts\IPSLibrary\install\DownloadListFiles\IPSLogger_FileList.ini
IPSModuleManager-Log-IPSFileVersionHandle2013-12-17 06:52:22.64 Set Version IPSLogger=2.50.6 (Loading)
IPSModuleManager-Log-IPSFileVersionHandle2013-12-17 06:52:22.64 Set Repository IPSLogger=https://raw.github.com/brownson/IPSLibrary/Development/
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:52:22.64 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\install\InstallationScripts\IPSLogger_Installation.ips.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:52:22.64 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\install\InstallationScripts\IPSLogger_Deinstallation.ips.php doesnt exists
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:22.64 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/install/InstallationScripts/IPSLogger_Installation.ips.php —> C:\IP-Symcon\scripts\IPSLibrary\install\InstallationScripts\IPSLogger_Installation.ips.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:23.68 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/install/InstallationScripts/IPSLogger_Deinstallation.ips.php —> C:\IP-Symcon\scripts\IPSLibrary\install\InstallationScripts\IPSLogger_Deinstallation.ips.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:24.55 Create Directory C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-17_0652\IPSLibrary\install\InitializationFiles\Default
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:24.55 Copy C:\IP-Symcon\scripts\IPSLibrary\install\InitializationFiles\Default\IPSLogger.ini --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-17_0652\IPSLibrary\install\InitializationFiles\Default\IPSLogger.ini
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:24.59 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/install/InitializationFiles/Default/IPSLogger.ini —> C:\IP-Symcon\scripts\IPSLibrary\install\InitializationFiles\Default\IPSLogger.ini
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:52:25.35 Register Script IPSLogger.ini in Program.IPSLibrary.install.InitializationFiles (File=C:\IP-Symcon\scripts\IPSLibrary\install\InitializationFiles\IPSLogger.ini)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:25.35 Created Script IPSLogger.ini=16768
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:52:25.35 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSLogger\IPSLogger.inc.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:52:25.36 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSLogger\IPSLogger_Constants.inc.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:52:25.36 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSLogger\IPSLogger_Output.inc.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:52:25.36 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSLogger\IPSLogger_PhpErrorHandler.inc.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:52:25.36 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSLogger\IPSLogger_ChangeSettings.ips.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:52:25.36 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSLogger\IPSLogger_ClearHtmlOut.ips.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:52:25.36 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSLogger\IPSLogger_ClearSingleOut.ips.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:52:25.36 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSLogger\IPSLogger_PurgeLogFiles.ips.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:52:25.36 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSLogger\IPSLogger_SendMail.ips.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:52:25.36 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSLogger\ProwlPHP.php doesnt exists
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:25.36 Create Directory C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSLogger
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:25.36 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSLogger/IPSLogger.inc.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSLogger\IPSLogger.inc.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:26.12 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSLogger/IPSLogger_Constants.inc.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSLogger\IPSLogger_Constants.inc.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:27.13 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSLogger/IPSLogger_Output.inc.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSLogger\IPSLogger_Output.inc.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:28.69 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSLogger/IPSLogger_PhpErrorHandler.inc.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSLogger\IPSLogger_PhpErrorHandler.inc.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:29.56 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSLogger/IPSLogger_ChangeSettings.ips.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSLogger\IPSLogger_ChangeSettings.ips.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:30.17 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSLogger/IPSLogger_ClearHtmlOut.ips.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSLogger\IPSLogger_ClearHtmlOut.ips.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:31.08 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSLogger/IPSLogger_ClearSingleOut.ips.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSLogger\IPSLogger_ClearSingleOut.ips.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:32.06 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSLogger/IPSLogger_PurgeLogFiles.ips.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSLogger\IPSLogger_PurgeLogFiles.ips.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:32.77 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSLogger/IPSLogger_SendMail.ips.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSLogger\IPSLogger_SendMail.ips.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:33.72 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSLogger/ProwlPHP.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSLogger\ProwlPHP.php
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:52:34.71 Register Script IPSLogger in Program.IPSLibrary.app.core.IPSLogger (File=C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSLogger\IPSLogger.inc.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:34.71 Created Category app=44776
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:34.71 Created Category core=48234
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:34.72 Created Category IPSLogger=53336
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:34.72 Created Script IPSLogger=34369
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:52:34.72 Register Script IPSLogger_Constants in Program.IPSLibrary.app.core.IPSLogger (File=C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSLogger\IPSLogger_Constants.inc.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:34.72 Created Script IPSLogger_Constants=11342
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:52:34.72 Register Script IPSLogger_Output in Program.IPSLibrary.app.core.IPSLogger (File=C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSLogger\IPSLogger_Output.inc.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:34.73 Created Script IPSLogger_Output=38013
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:52:34.73 Register Script IPSLogger_PhpErrorHandler in Program.IPSLibrary.app.core.IPSLogger (File=C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSLogger\IPSLogger_PhpErrorHandler.inc.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:34.73 Created Script IPSLogger_PhpErrorHandler=58104
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:52:34.73 Register Script IPSLogger_ChangeSettings in Program.IPSLibrary.app.core.IPSLogger (File=C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSLogger\IPSLogger_ChangeSettings.ips.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:34.74 Created Script IPSLogger_ChangeSettings=42572
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:52:34.74 Register Script IPSLogger_ClearHtmlOut in Program.IPSLibrary.app.core.IPSLogger (File=C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSLogger\IPSLogger_ClearHtmlOut.ips.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:34.74 Created Script IPSLogger_ClearHtmlOut=50189
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:52:34.74 Register Script IPSLogger_ClearSingleOut in Program.IPSLibrary.app.core.IPSLogger (File=C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSLogger\IPSLogger_ClearSingleOut.ips.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:34.74 Created Script IPSLogger_ClearSingleOut=51976
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:52:34.75 Register Script IPSLogger_PurgeLogFiles in Program.IPSLibrary.app.core.IPSLogger (File=C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSLogger\IPSLogger_PurgeLogFiles.ips.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:34.75 Created Script IPSLogger_PurgeLogFiles=29703
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:52:34.75 Register Script IPSLogger_SendMail in Program.IPSLibrary.app.core.IPSLogger (File=C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSLogger\IPSLogger_SendMail.ips.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:34.75 Created Script IPSLogger_SendMail=25247
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:52:34.75 Register Script ProwlPHP in Program.IPSLibrary.app.core.IPSLogger (File=C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSLogger\ProwlPHP.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:34.76 Created Script ProwlPHP=13742
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:52:34.76 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSLogger\Default\IPSLogger_IDs.inc.php doesnt exists
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:34.76 Create Directory C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSLogger\Default
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:34.76 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSLogger/Default/IPSLogger_IDs.inc.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSLogger\Default\IPSLogger_IDs.inc.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:35.70 Create User File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSLogger\IPSLogger_IDs.inc.php from Default File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSLogger\Default\IPSLogger_IDs.inc.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:35.70 Copy C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSLogger\Default\IPSLogger_IDs.inc.php --> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSLogger\IPSLogger_IDs.inc.php
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:52:35.70 Register Script IPSLogger_IDs in Program.IPSLibrary.app.core.IPSLogger (File=C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSLogger\IPSLogger_IDs.inc.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:35.71 Created Script IPSLogger_IDs=55061
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:52:35.71 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\config\core\IPSLogger\Default\IPSLogger_Configuration.inc.php doesnt exists
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:35.71 Create Directory C:\IP-Symcon\scripts\IPSLibrary\config\core\IPSLogger\Default
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:35.71 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/config/core/IPSLogger/Default/IPSLogger_Configuration.inc.php —> C:\IP-Symcon\scripts\IPSLibrary\config\core\IPSLogger\Default\IPSLogger_Configuration.inc.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:36.67 Create User File C:\IP-Symcon\scripts\IPSLibrary\config\core\IPSLogger\IPSLogger_Configuration.inc.php from Default File C:\IP-Symcon\scripts\IPSLibrary\config\core\IPSLogger\Default\IPSLogger_Configuration.inc.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:36.67 Copy C:\IP-Symcon\scripts\IPSLibrary\config\core\IPSLogger\Default\IPSLogger_Configuration.inc.php --> C:\IP-Symcon\scripts\IPSLibrary\config\core\IPSLogger\IPSLogger_Configuration.inc.php
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:52:36.68 Register Script IPSLogger_Configuration in Program.IPSLibrary.config.core.IPSLogger (File=C:\IP-Symcon\scripts\IPSLibrary\config\core\IPSLogger\IPSLogger_Configuration.inc.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.68 Created Category config=44131
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.68 Created Category core=55406
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.68 Created Category IPSLogger=19701
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.69 Created Script IPSLogger_Configuration=37013
IPSModuleManager-Log-IPSFileVersionHandle2013-12-17 06:52:36.69 Set Version IPSLogger=2.50.6 (Loaded)
IPSModuleManager-Log-IPSFileVersionHandle2013-12-17 06:52:36.69 Set Version IPSLogger=2.50.3 (Installing)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.71 Created Category data=44365
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.71 Created Category core=56817
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.71 Created Category IPSLogger=18984
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.71 Created Instance IPSLogger=49324, ModuleID={485D0419-BE97-4548-AA9C-C083EB82E61E}
Created Timer IPSLogger_PurgeLogFilesTimer=59510
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.75 Created VariableId SingleOut_Enabled=21570
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.75 Created VariableId SingleOut_Level=42319
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.75 Created VariableId SingleOut_Msg=34890
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.75 Created VariableId HtmlOut_Enabled=37991
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.75 Created VariableId HtmlOut_Level=48034
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.76 Created VariableId HtmlOut_MsgCount=49653
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.76 Created VariableId HtmlOut_MsgId=21862
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.76 Created VariableId HtmlOut_MsgList=50431
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.76 Created VariableId IPSOut_Enabled=26677
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.76 Created VariableId IPSOut_Level=18912
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.76 Created VariableId FileOut_Enabled=14707
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.76 Created VariableId FileOut_Level=29857
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.77 Created VariableId FileOut_Days=13857
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.77 Created VariableId Log4IPSOut_Enabled=23727
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.77 Created VariableId Log4IPSOut_Level=29064
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.77 Created VariableId Log4IPSOut_Days=30263
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.77 Created VariableId EMailOut_Enabled=45395
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.77 Created VariableId EMailOut_Level=11361
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.78 Created VariableId EMailOut_Priority=28748
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.78 Created VariableId EMailOut_SendDelay=45815
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.78 Created VariableId EMailOut_MsgList=55353
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.78 Created VariableId EchoSOut_Enabled=55393
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.78 Created VariableId EchoOut_Level=36016
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.78 Created VariableId ProwlOut_Enabled=46718
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.78 Created VariableId ProwlOut_Level=26884
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.79 Created VariableId ProwlOut_Priority=19801
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.84 Created Category Visualization=48762
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.84 Created Category WebFront=49459
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.84 Created Category System=15404
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.84 Created Category IPSLogger=33660
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.85 Created Category Output=10604
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.85 Created Category Settings=51930
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.85 Created Category Widget=45967
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.85 Created Category WebFront=38022
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.85 Created Category IPS=42713
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.85 Created Category File=26394
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.85 Created Category Log4IPS=50199
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.85 Created Category EMail=29486
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.85 Created Category Prowl=58135
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.86 Add WFCItem=‚SystemTP‘, Class=TabPane, Config={„title“:"",„name“:„SystemTP“,„icon“:„Gear“}
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.86 Add WFCItem=‚SystemTPLogWindow0652‘, Class=Category, Config={„title“:„Logging“,„name“:„SystemTPLogWindow0652“,„icon“:„Window“,„baseID“:10604,„enumBarColumns“:9,„selectorBarSteps“:5,„isBarBottomVisible“:false,„enablePercentageSlider“:true}
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.86 Add WFCItem=‚SystemTPLogSettings0652‘, Class=Category, Config={„title“:„Log Settings“,„name“:„SystemTPLogSettings0652“,„icon“:„Gear“,„baseID“:51930,„enumBarColumns“:9,„selectorBarSteps“:5,„isBarBottomVisible“:true,„enablePercentageSlider“:true}
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.86 Created Link Logging Window=25882
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.86 Created Link Output Widget=19702
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.86 Created Link Output WebFront=36925
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.86 Created Link Output IPS=42402
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.87 Created Link Output File=21716
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.87 Created Link Output Log4IPS=16121
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.87 Created Link Output EMail=30719
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.87 Created Link Output Echo=46660
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.87 Created Link Output Prowl=52941
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.87 Created Link Output Enabled=39825
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.87 Created Link Logging Level=26156
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.87 Created Link Last Message=51463
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.87 Created Link Clear Message=30413
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.87 Created Link Output Enabled=22505
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.88 Created Link Logging Level=55313
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.88 Created Link Message Count=22867
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.88 Created Link Last MessageID=51235
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.88 Created Link Clear Output=20624
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.88 Created Link Message List=43874
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.88 Created Link Output Enabled=44077
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.88 Created Link Logging Level=41090
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.88 Created Link Output Enabled=49841
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.88 Created Link Logging Level=42608
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.89 Created Link Purge Files after=18692
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.89 Created Link Execute Purge=55582
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.89 Created Link Output Enabled=12538
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.89 Created Link Logging Level=24576
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.89 Created Link Purge Files after=54480
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.89 Created Link Execute Purge=32763
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.89 Created Link Output Enabled=33595
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.89 Created Link Logging Level=22852
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.89 Created Link Priority=48391
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.89 Created Link Send Delay=53213
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.90 Created Link Message List=31337
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.90 Created Link Output Enabled=45148
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.90 Created Link Logging Level=56743
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.90 Created Link Priority=24696
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.90 Add WFCItem=‚IPSLogger_Widget‘, Class=InfoWidget, Config={„variableID“:34890,„scriptID“:51976,„name“:„IPSLogger_Widget“}
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.90 Created Category Mobile=13883
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.90 Created Category System=14668
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.91 Created Link Logging=46362
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.91 Created Category Logging=22765
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.91 Created Instance Widget=53006, ModuleID={485D0419-BE97-4548-AA9C-C083EB82E61E}
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.91 Created Link Output Enabled=48943
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.91 Created Link Logging Level=35513
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.91 Created Link Last Message=29503
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.91 Created Link Clear Message=50462
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.91 Created Instance WebFront=50761, ModuleID={485D0419-BE97-4548-AA9C-C083EB82E61E}
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.92 Created Link Output Enabled=45608
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.92 Created Link Logging Level=26419
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.92 Created Link Message Count=24071
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.92 Created Link Clear Output=48027
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.93 Created Instance IPS=47245, ModuleID={485D0419-BE97-4548-AA9C-C083EB82E61E}
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.93 Created Link Output Enabled=59249
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.93 Created Link Logging Level=53532
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.93 Created Instance LogFile=31715, ModuleID={485D0419-BE97-4548-AA9C-C083EB82E61E}
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.94 Created Link Output Enabled=46766
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.94 Created Link Logging Level=55035
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.94 Created Link Purge Files after=37856
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.94 Created Link Execute Purge=53610
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.94 Created Instance Log4IPS=21929, ModuleID={485D0419-BE97-4548-AA9C-C083EB82E61E}
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.94 Created Link Output Enabled=34709
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.94 Created Link Logging Level=30151
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.94 Created Link Purge Files after=58022
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.94 Created Link Execute Purge=27698
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.95 Created Instance EMail=26477, ModuleID={485D0419-BE97-4548-AA9C-C083EB82E61E}
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.95 Created Link Output Enabled=26005
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.95 Created Link Logging Level=34436
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.95 Created Link Priority=55771
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.95 Created Link Send Delay=47881
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.95 Created Link Message List=46273
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.95 Created Instance Prowl=39963, ModuleID={485D0419-BE97-4548-AA9C-C083EB82E61E}
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.95 Created Link Output Enabled=43914
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.95 Created Link Logging Level=37232
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.96 Created Link Priority=15919
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:36.96 Register Php ErrorHandler of IPSLogger in File __autoload.php
IPSModuleManager-Log-IPSFileVersionHandle2013-12-17 06:52:37.00 Set Version IPSLogger=2.50.3 (Installed)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:37.00 Module Download Ini File doesnt exists -> Load Ini File „https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary\install\DownloadListFiles\IPSModuleManagerGUI_FileList.ini“
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:37.00 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/install/DownloadListFiles/IPSModuleManagerGUI_FileList.ini —> C:\IP-Symcon\scripts\IPSLibrary\install\DownloadListFiles\IPSModuleManagerGUI_FileList.ini
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:37.69 Module Ini File doesnt exists -> Load Default Ini File „C:\IP-Symcon\scripts\IPSLibrary\install\InitializationFiles\Default\IPSModuleManagerGUI.ini“
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:37.69 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/install/InitializationFiles/Default/IPSModuleManagerGUI.ini —> C:\IP-Symcon\scripts\IPSLibrary\install\InitializationFiles\Default\IPSModuleManagerGUI.ini
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:38.63 Create User File C:\IP-Symcon\scripts\IPSLibrary\install\InitializationFiles\IPSModuleManagerGUI.ini from Default File C:\IP-Symcon\scripts\IPSLibrary\install\InitializationFiles\Default\IPSModuleManagerGUI.ini
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:38.63 Copy C:\IP-Symcon\scripts\IPSLibrary\install\InitializationFiles\Default\IPSModuleManagerGUI.ini --> C:\IP-Symcon\scripts\IPSLibrary\install\InitializationFiles\IPSModuleManagerGUI.ini
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:38.64 Copy C:\IP-Symcon\scripts\IPSLibrary\install\DownloadListFiles\IPSModuleManagerGUI_FileList.ini --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-17_0652\IPSLibrary\install\DownloadListFiles\IPSModuleManagerGUI_FileList.ini
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:38.64 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/install/DownloadListFiles/IPSModuleManagerGUI_FileList.ini —> C:\IP-Symcon\scripts\IPSLibrary\install\DownloadListFiles\IPSModuleManagerGUI_FileList.ini
IPSModuleManager-Log-IPSFileVersionHandle2013-12-17 06:52:39.47 Set Version IPSModuleManagerGUI=2.50.11 (Loading)
IPSModuleManager-Log-IPSFileVersionHandle2013-12-17 06:52:39.47 Set Repository IPSModuleManagerGUI=https://raw.github.com/brownson/IPSLibrary/Development/
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:52:39.47 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\install\InstallationScripts\IPSModuleManagerGUI_Installation.ips.php doesnt exists
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:39.47 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/install/InstallationScripts/IPSModuleManagerGUI_Installation.ips.php —> C:\IP-Symcon\scripts\IPSLibrary\install\InstallationScripts\IPSModuleManagerGUI_Installation.ips.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:40.17 Copy C:\IP-Symcon\scripts\IPSLibrary\install\InitializationFiles\Default\IPSModuleManagerGUI.ini --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-17_0652\IPSLibrary\install\InitializationFiles\Default\IPSModuleManagerGUI.ini
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:40.18 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/install/InitializationFiles/Default/IPSModuleManagerGUI.ini —> C:\IP-Symcon\scripts\IPSLibrary\install\InitializationFiles\Default\IPSModuleManagerGUI.ini
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:52:41.09 Register Script IPSModuleManagerGUI.ini in Program.IPSLibrary.install.InitializationFiles (File=C:\IP-Symcon\scripts\IPSLibrary\install\InitializationFiles\IPSModuleManagerGUI.ini)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:41.09 Created Script IPSModuleManagerGUI.ini=53553
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:52:41.09 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\modules\IPSModuleManagerGUI\IPSModuleManagerGUI.inc.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:52:41.09 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\modules\IPSModuleManagerGUI\IPSModuleManagerGUI_Constants.inc.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:52:41.10 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\modules\IPSModuleManagerGUI\IPSModuleManagerGUI_Utils.inc.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:52:41.10 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\modules\IPSModuleManagerGUI\IPSModuleManagerGUI_SearchUpdates.ips.php doesnt exists
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:41.10 Create Directory C:\IP-Symcon\scripts\IPSLibrary\app\modules\IPSModuleManagerGUI
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:41.10 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/modules/IPSModuleManagerGUI/IPSModuleManagerGUI.inc.php —> C:\IP-Symcon\scripts\IPSLibrary\app\modules\IPSModuleManagerGUI\IPSModuleManagerGUI.inc.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:42.34 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/modules/IPSModuleManagerGUI/IPSModuleManagerGUI_Constants.inc.php —> C:\IP-Symcon\scripts\IPSLibrary\app\modules\IPSModuleManagerGUI\IPSModuleManagerGUI_Constants.inc.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:43.02 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/modules/IPSModuleManagerGUI/IPSModuleManagerGUI_Utils.inc.php —> C:\IP-Symcon\scripts\IPSLibrary\app\modules\IPSModuleManagerGUI\IPSModuleManagerGUI_Utils.inc.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:43.98 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/modules/IPSModuleManagerGUI/IPSModuleManagerGUI_SearchUpdates.ips.php —> C:\IP-Symcon\scripts\IPSLibrary\app\modules\IPSModuleManagerGUI\IPSModuleManagerGUI_SearchUpdates.ips.php
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:52:45.06 Register Script IPSModuleManagerGUI in Program.IPSLibrary.app.modules.IPSModuleManagerGUI (File=C:\IP-Symcon\scripts\IPSLibrary\app\modules\IPSModuleManagerGUI\IPSModuleManagerGUI.inc.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:45.06 Created Category modules=44042
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:45.06 Created Category IPSModuleManagerGUI=27351
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:45.07 Created Script IPSModuleManagerGUI=54283
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:52:45.07 Register Script IPSModuleManagerGUI_Constants in Program.IPSLibrary.app.modules.IPSModuleManagerGUI (File=C:\IP-Symcon\scripts\IPSLibrary\app\modules\IPSModuleManagerGUI\IPSModuleManagerGUI_Constants.inc.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:45.07 Created Script IPSModuleManagerGUI_Constants=35995
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:52:45.07 Register Script IPSModuleManagerGUI_Utils in Program.IPSLibrary.app.modules.IPSModuleManagerGUI (File=C:\IP-Symcon\scripts\IPSLibrary\app\modules\IPSModuleManagerGUI\IPSModuleManagerGUI_Utils.inc.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:45.08 Created Script IPSModuleManagerGUI_Utils=19380
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:52:45.08 Register Script IPSModuleManagerGUI_SearchUpdates in Program.IPSLibrary.app.modules.IPSModuleManagerGUI (File=C:\IP-Symcon\scripts\IPSLibrary\app\modules\IPSModuleManagerGUI\IPSModuleManagerGUI_SearchUpdates.ips.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:45.08 Created Script IPSModuleManagerGUI_SearchUpdates=16831
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:52:45.08 Backup NOT possible - Source File C:\IP-Symcon\webfront\user\IPSModuleManagerGUI\jquery.min.js doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:52:45.09 Backup NOT possible - Source File C:\IP-Symcon\webfront\user\IPSModuleManagerGUI\IPSModuleManagerGUI.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:52:45.09 Backup NOT possible - Source File C:\IP-Symcon\webfront\user\IPSModuleManagerGUI\IPSModuleManagerGUI.css doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:52:45.09 Backup NOT possible - Source File C:\IP-Symcon\webfront\user\IPSModuleManagerGUI\IPSModuleManagerGUI_Overview.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:52:45.09 Backup NOT possible - Source File C:\IP-Symcon\webfront\user\IPSModuleManagerGUI\IPSModuleManagerGUI_Updates.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:52:45.09 Backup NOT possible - Source File C:\IP-Symcon\webfront\user\IPSModuleManagerGUI\IPSModuleManagerGUI_Logs.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:52:45.09 Backup NOT possible - Source File C:\IP-Symcon\webfront\user\IPSModuleManagerGUI\IPSModuleManagerGUI_LogFile.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:52:45.09 Backup NOT possible - Source File C:\IP-Symcon\webfront\user\IPSModuleManagerGUI\IPSModuleManagerGUI_NewModule.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:52:45.09 Backup NOT possible - Source File C:\IP-Symcon\webfront\user\IPSModuleManagerGUI\IPSModuleManagerGUI_Module.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:52:45.09 Backup NOT possible - Source File C:\IP-Symcon\webfront\user\IPSModuleManagerGUI\IPSModuleManagerGUI_Wizard.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:52:45.09 Backup NOT possible - Source File C:\IP-Symcon\webfront\user\IPSModuleManagerGUI\IPSModuleManagerGUI_Receiver.php doesnt exists
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:45.09 Create Directory C:\IP-Symcon\webfront\user\IPSModuleManagerGUI
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:45.09 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/webfront/IPSModuleManagerGUI/jquery.min.js —> C:\IP-Symcon\webfront\user\IPSModuleManagerGUI\jquery.min.js
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:46.49 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/webfront/IPSModuleManagerGUI/IPSModuleManagerGUI.php —> C:\IP-Symcon\webfront\user\IPSModuleManagerGUI\IPSModuleManagerGUI.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:47.46 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/webfront/IPSModuleManagerGUI/IPSModuleManagerGUI.css —> C:\IP-Symcon\webfront\user\IPSModuleManagerGUI\IPSModuleManagerGUI.css
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:48.43 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/webfront/IPSModuleManagerGUI/IPSModuleManagerGUI_Overview.php —> C:\IP-Symcon\webfront\user\IPSModuleManagerGUI\IPSModuleManagerGUI_Overview.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:49.41 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/webfront/IPSModuleManagerGUI/IPSModuleManagerGUI_Updates.php —> C:\IP-Symcon\webfront\user\IPSModuleManagerGUI\IPSModuleManagerGUI_Updates.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:50.69 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/webfront/IPSModuleManagerGUI/IPSModuleManagerGUI_Logs.php —> C:\IP-Symcon\webfront\user\IPSModuleManagerGUI\IPSModuleManagerGUI_Logs.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:51.64 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/webfront/IPSModuleManagerGUI/IPSModuleManagerGUI_LogFile.php —> C:\IP-Symcon\webfront\user\IPSModuleManagerGUI\IPSModuleManagerGUI_LogFile.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:52.56 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/webfront/IPSModuleManagerGUI/IPSModuleManagerGUI_NewModule.php —> C:\IP-Symcon\webfront\user\IPSModuleManagerGUI\IPSModuleManagerGUI_NewModule.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:53.51 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/webfront/IPSModuleManagerGUI/IPSModuleManagerGUI_Module.php —> C:\IP-Symcon\webfront\user\IPSModuleManagerGUI\IPSModuleManagerGUI_Module.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:54.19 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/webfront/IPSModuleManagerGUI/IPSModuleManagerGUI_Wizard.php —> C:\IP-Symcon\webfront\user\IPSModuleManagerGUI\IPSModuleManagerGUI_Wizard.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:55.44 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/webfront/IPSModuleManagerGUI/IPSModuleManagerGUI_Receiver.php —> C:\IP-Symcon\webfront\user\IPSModuleManagerGUI\IPSModuleManagerGUI_Receiver.php
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:52:56.39 Script jquery.min.js NOT registered (Filepath)
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:52:56.39 Script IPSModuleManagerGUI NOT registered (Filepath)
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:52:56.39 Script IPSModuleManagerGUI.css NOT registered (Filepath)
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:52:56.39 Script IPSModuleManagerGUI_Overview NOT registered (Filepath)
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:52:56.39 Script IPSModuleManagerGUI_Updates NOT registered (Filepath)
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:52:56.39 Script IPSModuleManagerGUI_Logs NOT registered (Filepath)
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:52:56.39 Script IPSModuleManagerGUI_LogFile NOT registered (Filepath)
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:52:56.39 Script IPSModuleManagerGUI_NewModule NOT registered (Filepath)
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:52:56.39 Script IPSModuleManagerGUI_Module NOT registered (Filepath)
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:52:56.40 Script IPSModuleManagerGUI_Wizard NOT registered (Filepath)
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:52:56.40 Script IPSModuleManagerGUI_Receiver NOT registered (Filepath)
IPSModuleManager-Log-IPSFileVersionHandle2013-12-17 06:52:56.40 Set Version IPSModuleManagerGUI=2.50.11 (Loaded)
IPSModuleManager-Log-IPSFileVersionHandle2013-12-17 06:52:56.40 Set Version IPSModuleManagerGUI=2.50.1 (Installing)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:56.42 Created Category modules=53637
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:56.42 Created Category IPSModuleManagerGUI=32866
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:56.42 Created Timer SearchUpdates=55131
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:56.42 Created VariableId Action=57115
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:56.42 Created VariableId Module=36303
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:56.42 Created VariableId Info=18887
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:56.42 Created VariableId HTML=28108
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:56.43 Created Category IPSModuleManagerGUI=35622
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:56.43 Empty Category ID=35622
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:56.43 Created Link IPSLibrary=42418
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:56.43 Add WFCItem=‚SystemTPLibrary‘, Class=Category, Config={„title“:„IPSLibrary“,„name“:„SystemTPLibrary“,„icon“:„ErlenmeyerFlask“,„baseID“:35622,„enumBarColumns“:9,„selectorBarSteps“:5,„isBarBottomVisible“:false,„enablePercentageSlider“:true}
IPSModuleManager-Log-IPSFileVersionHandle2013-12-17 06:52:56.43 Set Version IPSModuleManagerGUI=2.50.1 (Installed)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:56.44 Module Download Ini File doesnt exists -> Load Ini File „https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary\install\DownloadListFiles\IPSComponent_FileList.ini“
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:56.44 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/install/DownloadListFiles/IPSComponent_FileList.ini —> C:\IP-Symcon\scripts\IPSLibrary\install\DownloadListFiles\IPSComponent_FileList.ini
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:52:57.10 Module Ini File doesnt exists -> Load Default Ini File „C:\IP-Symcon\scripts\IPSLibrary\install\InitializationFiles\Default\IPSComponent.ini“
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:57.10 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/install/InitializationFiles/Default/IPSComponent.ini —> C:\IP-Symcon\scripts\IPSLibrary\install\InitializationFiles\Default\IPSComponent.ini
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:58.07 Create User File C:\IP-Symcon\scripts\IPSLibrary\install\InitializationFiles\IPSComponent.ini from Default File C:\IP-Symcon\scripts\IPSLibrary\install\InitializationFiles\Default\IPSComponent.ini
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:58.07 Copy C:\IP-Symcon\scripts\IPSLibrary\install\InitializationFiles\Default\IPSComponent.ini --> C:\IP-Symcon\scripts\IPSLibrary\install\InitializationFiles\IPSComponent.ini
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:58.08 Copy C:\IP-Symcon\scripts\IPSLibrary\install\DownloadListFiles\IPSComponent_FileList.ini --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-17_0652\IPSLibrary\install\DownloadListFiles\IPSComponent_FileList.ini
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:58.08 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/install/DownloadListFiles/IPSComponent_FileList.ini —> C:\IP-Symcon\scripts\IPSLibrary\install\DownloadListFiles\IPSComponent_FileList.ini
IPSModuleManager-Log-IPSFileVersionHandle2013-12-17 06:52:58.95 Set Version IPSComponent=2.50.32 (Loading)
IPSModuleManager-Log-IPSFileVersionHandle2013-12-17 06:52:58.95 Set Repository IPSComponent=https://raw.github.com/brownson/IPSLibrary/Development/
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:52:58.95 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\install\InstallationScripts\IPSComponent_Installation.ips.php doesnt exists
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:52:58.95 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/install/InstallationScripts/IPSComponent_Installation.ips.php —> C:\IP-Symcon\scripts\IPSLibrary\install\InstallationScripts\IPSComponent_Installation.ips.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:53:00.40 Copy C:\IP-Symcon\scripts\IPSLibrary\install\InitializationFiles\Default\IPSComponent.ini --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-17_0652\IPSLibrary\install\InitializationFiles\Default\IPSComponent.ini
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:53:00.40 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/install/InitializationFiles/Default/IPSComponent.ini —> C:\IP-Symcon\scripts\IPSLibrary\install\InitializationFiles\Default\IPSComponent.ini
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:53:00.93 Register Script IPSComponent.ini in Program.IPSLibrary.install.InitializationFiles (File=C:\IP-Symcon\scripts\IPSLibrary\install\InitializationFiles\IPSComponent.ini)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:53:00.93 Created Script IPSComponent.ini=46212
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:53:00.94 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponent.class.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:53:00.94 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSModule.class.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:53:00.94 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentCam\IPSComponentCam.class.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:53:00.94 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentCam\IPSComponentCam_Abus.class.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:53:00.94 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentCam\IPSComponentCam_Allnet.class.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:53:00.94 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentCam\IPSComponentCam_Android.class.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:53:00.94 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentCam\IPSComponentCam_Axis.class.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:53:00.94 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentCam\IPSComponentCam_AxisM7001.class.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:53:00.94 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentCam\IPSComponentCam_Cisco.class.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:53:00.94 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentCam\IPSComponentCam_DLink932.class.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:53:00.94 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentCam\IPSComponentCam_DLink.class.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:53:00.94 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentCam\IPSComponentCam_Edimax.class.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:53:00.95 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentCam\IPSComponentCam_Instar.class.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:53:00.95 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentCam\IPSComponentCam_Foscam.class.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:53:00.95 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentCam\IPSComponentCam_Foscam89x.class.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:53:00.95 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentCam\IPSComponentCam_Mobotix.class.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:53:00.95 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentCam\IPSComponentCam_Planet.class.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:53:00.95 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentCam\IPSComponentCam_Vivotek.class.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:53:00.95 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentCam\IPSComponentCam_YCam.class.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:53:00.95 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentPlayer\IPSComponentPlayer.class.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:53:00.95 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentPlayer\IPSComponentPlayer_Sonos.class.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:53:00.95 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentPlayer\IPSComponentPlayer_Mediaplayer.class.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:53:00.95 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentPlayer\IPSComponentPlayer_Squeezebox.class.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:53:00.95 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentPlayer\IPSModulePlayer.class.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:53:00.96 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentPlayer\IPSModulePlayer_NetPlayer.class.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:53:00.96 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentShutter\IPSComponentShutter.class.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:53:00.96 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentShutter\IPSComponentShutter_Homematic.class.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:53:00.96 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentShutter\IPSComponentShutter_Dummy.class.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:53:00.96 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentShutter\IPSComponentShutter_1Wire.class.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:53:00.96 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentShutter\IPSComponentShutter_Enocean.class.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:53:00.96 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentShutter\IPSComponentShutter_FS20.class.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:53:00.96 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentShutter\IPSComponentShutter_IPSShutterControl.class.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:53:00.96 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentShutter\IPSComponentShutter_LCN.class.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:53:00.96 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentShutter\IPSComponentShutter_EIB.class.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:53:00.96 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentShutter\IPSComponentShutter_MoellerEaton.class.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:53:00.96 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentShutter\IPSComponentShutter_zwave.class.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:53:00.97 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentShutter\IPSModuleShutter.class.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:53:00.97 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentShutter\IPSModuleShutter_IPSShadowing.class.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:53:00.97 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentSwitch\IPSComponentSwitch.class.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:53:00.97 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentSwitch\IPSComponentSwitch_1WireD2408.class.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:53:00.97 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentSwitch\IPSComponentSwitch_1WireD2413.class.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:53:00.97 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentSwitch\IPSComponentSwitch_Dummy.class.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:53:00.97 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentSwitch\IPSComponentSwitch_EatonMoeller.class.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:53:00.97 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentSwitch\IPSComponentSwitch_EIB.class.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:53:00.97 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentSwitch\IPSComponentSwitch_FS20.class.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:53:00.97 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentSwitch\IPSComponentSwitch_Homematic.class.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:53:00.97 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentSwitch\IPSComponentSwitch_ModBus.class.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:53:00.97 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentSwitch\IPSComponentSwitch_LCN.class.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:53:00.97 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentSwitch\IPSComponentSwitch_ZW.class.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:53:00.98 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentSwitch\IPSModuleSwitch.class.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:53:00.98 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentSwitch\IPSModuleSwitch_IPSLight.class.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:53:00.98 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentDimmer\IPSComponentDimmer.class.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:53:00.98 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentDimmer\IPSComponentDimmer_Dummy.class.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:53:00.98 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentDimmer\IPSComponentDimmer_EIB.class.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:53:00.98 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentDimmer\IPSComponentDimmer_FS20.class.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:53:00.98 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentDimmer\IPSComponentDimmer_Homematic.class.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:53:00.98 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentDimmer\IPSComponentDimmer_ZW.class.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:53:00.98 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentDimmer\IPSModuleDimmer.class.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:53:00.98 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentRGB\IPSComponentRGB.class.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:53:00.98 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentRGB\IPSComponentRGB_IPS868.class.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:53:00.98 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentRGB\IPSComponentRGB_Dummy.class.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:53:00.98 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentRGB\IPSModuleRGB.class.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:53:00.99 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentAVControl\IPSComponentAVControl.class.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:53:00.99 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentAVControl\IPSComponentAVControl_AudioMax.class.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:53:00.99 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentAVControl\IPSModuleAVControl.class.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:53:00.99 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentAVControl\IPSModuleAVControl_Entertainment.class.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:53:00.99 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentSensor\IPSComponentSensor.class.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:53:00.99 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentSensor\IPSComponentSensor_Button.class.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:53:00.99 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentSensor\IPSComponentSensor_IRTrans.class.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:53:00.99 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentSensor\IPSModuleSensor.class.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:53:01.99 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentSensor\IPSModuleSensor_IPSShadowing.class.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:53:01.99 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentSensor\IPSModuleSensor_IRTrans.class.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:53:01.99 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentSensor\IPSModuleSensor_NetPlayer.class.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:53:01.99 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentSensor\IPSModuleSensor_Entertainment.class.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:53:01.00 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentSensor\IPSModuleSensor_IPSLight.class.php doesnt exists
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:53:01.00 Create Directory C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:53:01.00 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSComponent/IPSComponent.class.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponent.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:53:01.88 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSComponent/IPSModule.class.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSModule.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:53:02.88 Create Directory C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentCam
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:53:02.88 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSComponent/IPSComponentCam/IPSComponentCam.class.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentCam\IPSComponentCam.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:53:03.89 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSComponent/IPSComponentCam/IPSComponentCam_Abus.class.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentCam\IPSComponentCam_Abus.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:53:04.86 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSComponent/IPSComponentCam/IPSComponentCam_Allnet.class.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentCam\IPSComponentCam_Allnet.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:53:05.87 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSComponent/IPSComponentCam/IPSComponentCam_Android.class.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentCam\IPSComponentCam_Android.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:53:06.88 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSComponent/IPSComponentCam/IPSComponentCam_Axis.class.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentCam\IPSComponentCam_Axis.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:53:07.76 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSComponent/IPSComponentCam/IPSComponentCam_AxisM7001.class.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentCam\IPSComponentCam_AxisM7001.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:53:08.40 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSComponent/IPSComponentCam/IPSComponentCam_Cisco.class.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentCam\IPSComponentCam_Cisco.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:53:09.32 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSComponent/IPSComponentCam/IPSComponentCam_DLink932.class.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentCam\IPSComponentCam_DLink932.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:53:10.28 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSComponent/IPSComponentCam/IPSComponentCam_DLink.class.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentCam\IPSComponentCam_DLink.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:53:11.25 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSComponent/IPSComponentCam/IPSComponentCam_Edimax.class.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentCam\IPSComponentCam_Edimax.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:53:12.23 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSComponent/IPSComponentCam/IPSComponentCam_Instar.class.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentCam\IPSComponentCam_Instar.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:53:13.22 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSComponent/IPSComponentCam/IPSComponentCam_Foscam.class.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentCam\IPSComponentCam_Foscam.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:53:14.25 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSComponent/IPSComponentCam/IPSComponentCam_Foscam89x.class.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentCam\IPSComponentCam_Foscam89x.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:53:15.24 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSComponent/IPSComponentCam/IPSComponentCam_Mobotix.class.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentCam\IPSComponentCam_Mobotix.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:53:15.95 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSComponent/IPSComponentCam/IPSComponentCam_Planet.class.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentCam\IPSComponentCam_Planet.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:53:16.93 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSComponent/IPSComponentCam/IPSComponentCam_Vivotek.class.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentCam\IPSComponentCam_Vivotek.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:53:18.46 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSComponent/IPSComponentCam/IPSComponentCam_YCam.class.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentCam\IPSComponentCam_YCam.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:53:19.33 Create Directory C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentPlayer
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:53:19.33 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSComponent/IPSComponentPlayer/IPSComponentPlayer.class.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentPlayer\IPSComponentPlayer.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:53:20.28 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSComponent/IPSComponentPlayer/IPSComponentPlayer_Sonos.class.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentPlayer\IPSComponentPlayer_Sonos.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:53:21.27 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSComponent/IPSComponentPlayer/IPSComponentPlayer_Mediaplayer.class.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentPlayer\IPSComponentPlayer_Mediaplayer.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:53:22.25 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSComponent/IPSComponentPlayer/IPSComponentPlayer_Squeezebox.class.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentPlayer\IPSComponentPlayer_Squeezebox.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:53:23.47 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSComponent/IPSComponentPlayer/IPSModulePlayer.class.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentPlayer\IPSModulePlayer.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:53:24.23 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSComponent/IPSComponentPlayer/IPSModulePlayer_NetPlayer.class.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentPlayer\IPSModulePlayer_NetPlayer.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:53:25.21 Create Directory C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentShutter
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:53:25.21 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSComponent/IPSComponentShutter/IPSComponentShutter.class.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentShutter\IPSComponentShutter.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:53:26.20 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSComponent/IPSComponentShutter/IPSComponentShutter_Homematic.class.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentShutter\IPSComponentShutter_Homematic.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:53:27.19 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSComponent/IPSComponentShutter/IPSComponentShutter_Dummy.class.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentShutter\IPSComponentShutter_Dummy.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:53:28.17 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSComponent/IPSComponentShutter/IPSComponentShutter_1Wire.class.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentShutter\IPSComponentShutter_1Wire.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:53:28.93 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSComponent/IPSComponentShutter/IPSComponentShutter_Enocean.class.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentShutter\IPSComponentShutter_Enocean.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:53:29.90 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSComponent/IPSComponentShutter/IPSComponentShutter_FS20.class.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentShutter\IPSComponentShutter_FS20.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:53:30.92 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSComponent/IPSComponentShutter/IPSComponentShutter_IPSShutterControl.class.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentShutter\IPSComponentShutter_IPSShutterControl.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:53:31.89 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSComponent/IPSComponentShutter/IPSComponentShutter_LCN.class.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentShutter\IPSComponentShutter_LCN.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:53:33.16 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSComponent/IPSComponentShutter/IPSComponentShutter_EIB.class.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentShutter\IPSComponentShutter_EIB.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:53:34.18 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSComponent/IPSComponentShutter/IPSComponentShutter_MoellerEaton.class.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentShutter\IPSComponentShutter_MoellerEaton.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:53:35.16 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSComponent/IPSComponentShutter/IPSComponentShutter_zwave.class.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentShutter\IPSComponentShutter_zwave.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:53:36.14 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSComponent/IPSComponentShutter/IPSModuleShutter.class.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentShutter\IPSModuleShutter.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:53:37.03 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSComponent/IPSComponentShutter/IPSModuleShutter_IPSShadowing.class.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentShutter\IPSModuleShutter_IPSShadowing.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:53:37.94 Create Directory C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentSwitch
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:53:37.98 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSComponent/IPSComponentSwitch/IPSComponentSwitch.class.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentSwitch\IPSComponentSwitch.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:53:38.91 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSComponent/IPSComponentSwitch/IPSComponentSwitch_1WireD2408.class.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentSwitch\IPSComponentSwitch_1WireD2408.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:53:39.86 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSComponent/IPSComponentSwitch/IPSComponentSwitch_1WireD2413.class.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentSwitch\IPSComponentSwitch_1WireD2413.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:53:40.77 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSComponent/IPSComponentSwitch/IPSComponentSwitch_Dummy.class.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentSwitch\IPSComponentSwitch_Dummy.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:53:41.77 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSComponent/IPSComponentSwitch/IPSComponentSwitch_EatonMoeller.class.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentSwitch\IPSComponentSwitch_EatonMoeller.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:53:42.72 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSComponent/IPSComponentSwitch/IPSComponentSwitch_EIB.class.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentSwitch\IPSComponentSwitch_EIB.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:53:43.64 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSComponent/IPSComponentSwitch/IPSComponentSwitch_FS20.class.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentSwitch\IPSComponentSwitch_FS20.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:53:44.58 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSComponent/IPSComponentSwitch/IPSComponentSwitch_Homematic.class.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentSwitch\IPSComponentSwitch_Homematic.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:53:45.67 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSComponent/IPSComponentSwitch/IPSComponentSwitch_ModBus.class.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentSwitch\IPSComponentSwitch_ModBus.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:53:46.58 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSComponent/IPSComponentSwitch/IPSComponentSwitch_LCN.class.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentSwitch\IPSComponentSwitch_LCN.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:53:47.52 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSComponent/IPSComponentSwitch/IPSComponentSwitch_ZW.class.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentSwitch\IPSComponentSwitch_ZW.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:53:48.50 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSComponent/IPSComponentSwitch/IPSModuleSwitch.class.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentSwitch\IPSModuleSwitch.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:53:49.46 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSComponent/IPSComponentSwitch/IPSModuleSwitch_IPSLight.class.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentSwitch\IPSModuleSwitch_IPSLight.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:53:50.13 Create Directory C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentDimmer
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:53:50.13 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSComponent/IPSComponentDimmer/IPSComponentDimmer.class.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentDimmer\IPSComponentDimmer.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:53:51.41 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSComponent/IPSComponentDimmer/IPSComponentDimmer_Dummy.class.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentDimmer\IPSComponentDimmer_Dummy.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:53:52.39 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSComponent/IPSComponentDimmer/IPSComponentDimmer_EIB.class.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentDimmer\IPSComponentDimmer_EIB.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:53:53.41 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSComponent/IPSComponentDimmer/IPSComponentDimmer_FS20.class.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentDimmer\IPSComponentDimmer_FS20.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:53:54.37 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSComponent/IPSComponentDimmer/IPSComponentDimmer_Homematic.class.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentDimmer\IPSComponentDimmer_Homematic.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:53:55.35 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSComponent/IPSComponentDimmer/IPSComponentDimmer_ZW.class.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentDimmer\IPSComponentDimmer_ZW.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:53:56.33 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSComponent/IPSComponentDimmer/IPSModuleDimmer.class.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentDimmer\IPSModuleDimmer.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:53:57.28 Create Directory C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentRGB
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:53:57.28 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSComponent/IPSComponentRGB/IPSComponentRGB.class.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentRGB\IPSComponentRGB.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:53:57.97 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSComponent/IPSComponentRGB/IPSComponentRGB_IPS868.class.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentRGB\IPSComponentRGB_IPS868.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:53:58.86 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSComponent/IPSComponentRGB/IPSComponentRGB_Dummy.class.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentRGB\IPSComponentRGB_Dummy.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:53:59.50 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSComponent/IPSComponentRGB/IPSModuleRGB.class.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentRGB\IPSModuleRGB.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:54:00.67 Create Directory C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentAVControl
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:54:00.67 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSComponent/IPSComponentAVControl/IPSComponentAVControl.class.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentAVControl\IPSComponentAVControl.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:54:01.45 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSComponent/IPSComponentAVControl/IPSComponentAVControl_AudioMax.class.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentAVControl\IPSComponentAVControl_AudioMax.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:54:02.45 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSComponent/IPSComponentAVControl/IPSModuleAVControl.class.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentAVControl\IPSModuleAVControl.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:54:03.14 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSComponent/IPSComponentAVControl/IPSModuleAVControl_Entertainment.class.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentAVControl\IPSModuleAVControl_Entertainment.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:54:04.04 Create Directory C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentSensor
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:54:04.04 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSComponent/IPSComponentSensor/IPSComponentSensor.class.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentSensor\IPSComponentSensor.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:54:04.92 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSComponent/IPSComponentSensor/IPSComponentSensor_Button.class.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentSensor\IPSComponentSensor_Button.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:54:05.74 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSComponent/IPSComponentSensor/IPSComponentSensor_IRTrans.class.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentSensor\IPSComponentSensor_IRTrans.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:54:06.75 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSComponent/IPSComponentSensor/IPSModuleSensor.class.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentSensor\IPSModuleSensor.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:54:07.44 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSComponent/IPSComponentSensor/IPSModuleSensor_IPSShadowing.class.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentSensor\IPSModuleSensor_IPSShadowing.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:54:08.37 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSComponent/IPSComponentSensor/IPSModuleSensor_IRTrans.class.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentSensor\IPSModuleSensor_IRTrans.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:54:09.08 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSComponent/IPSComponentSensor/IPSModuleSensor_NetPlayer.class.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentSensor\IPSModuleSensor_NetPlayer.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:54:10.09 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSComponent/IPSComponentSensor/IPSModuleSensor_Entertainment.class.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentSensor\IPSModuleSensor_Entertainment.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:54:11.06 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSComponent/IPSComponentSensor/IPSModuleSensor_IPSLight.class.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentSensor\IPSModuleSensor_IPSLight.class.php
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:54:12.08 Register Script IPSComponent in Program.IPSLibrary.app.core.IPSComponent (File=C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponent.class.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:12.08 Created Category IPSComponent=44535
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:12.08 Created Script IPSComponent=48173
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:54:12.09 Register Script IPSModule in Program.IPSLibrary.app.core.IPSComponent (File=C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSModule.class.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:12.09 Created Script IPSModule=13177
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:54:12.09 Register Script IPSComponentCam in Program.IPSLibrary.app.core.IPSComponent.IPSComponentCam (File=C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentCam\IPSComponentCam.class.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:12.09 Created Category IPSComponentCam=20247
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:12.10 Created Script IPSComponentCam=16328
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:54:12.10 Register Script IPSComponentCam_Abus in Program.IPSLibrary.app.core.IPSComponent.IPSComponentCam (File=C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentCam\IPSComponentCam_Abus.class.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:12.10 Created Script IPSComponentCam_Abus=15655
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:54:12.10 Register Script IPSComponentCam_Allnet in Program.IPSLibrary.app.core.IPSComponent.IPSComponentCam (File=C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentCam\IPSComponentCam_Allnet.class.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:12.11 Created Script IPSComponentCam_Allnet=47068
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:54:12.11 Register Script IPSComponentCam_Android in Program.IPSLibrary.app.core.IPSComponent.IPSComponentCam (File=C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentCam\IPSComponentCam_Android.class.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:12.11 Created Script IPSComponentCam_Android=40186
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:54:12.11 Register Script IPSComponentCam_Axis in Program.IPSLibrary.app.core.IPSComponent.IPSComponentCam (File=C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentCam\IPSComponentCam_Axis.class.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:12.12 Created Script IPSComponentCam_Axis=10200
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:54:12.12 Register Script IPSComponentCam_AxisM7001 in Program.IPSLibrary.app.core.IPSComponent.IPSComponentCam (File=C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentCam\IPSComponentCam_AxisM7001.class.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:12.12 Created Script IPSComponentCam_AxisM7001=13610
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:54:12.12 Register Script IPSComponentCam_Cisco in Program.IPSLibrary.app.core.IPSComponent.IPSComponentCam (File=C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentCam\IPSComponentCam_Cisco.class.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:12.13 Created Script IPSComponentCam_Cisco=18825
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:54:12.13 Register Script IPSComponentCam_DLink932 in Program.IPSLibrary.app.core.IPSComponent.IPSComponentCam (File=C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentCam\IPSComponentCam_DLink932.class.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:12.13 Created Script IPSComponentCam_DLink932=53077
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:54:12.13 Register Script IPSComponentCam_DLink in Program.IPSLibrary.app.core.IPSComponent.IPSComponentCam (File=C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentCam\IPSComponentCam_DLink.class.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:12.14 Created Script IPSComponentCam_DLink=15249
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:54:12.14 Register Script IPSComponentCam_Edimax in Program.IPSLibrary.app.core.IPSComponent.IPSComponentCam (File=C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentCam\IPSComponentCam_Edimax.class.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:12.14 Created Script IPSComponentCam_Edimax=44567
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:54:12.14 Register Script IPSComponentCam_Instar in Program.IPSLibrary.app.core.IPSComponent.IPSComponentCam (File=C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentCam\IPSComponentCam_Instar.class.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:12.15 Created Script IPSComponentCam_Instar=13528
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:54:12.15 Register Script IPSComponentCam_Foscam in Program.IPSLibrary.app.core.IPSComponent.IPSComponentCam (File=C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentCam\IPSComponentCam_Foscam.class.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:12.15 Created Script IPSComponentCam_Foscam=33389
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:54:12.15 Register Script IPSComponentCam_Foscam89x in Program.IPSLibrary.app.core.IPSComponent.IPSComponentCam (File=C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentCam\IPSComponentCam_Foscam89x.class.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:12.15 Created Script IPSComponentCam_Foscam89x=37807
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:54:12.16 Register Script IPSComponentCam_Mobotix in Program.IPSLibrary.app.core.IPSComponent.IPSComponentCam (File=C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentCam\IPSComponentCam_Mobotix.class.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:12.16 Created Script IPSComponentCam_Mobotix=46529
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:54:12.16 Register Script IPSComponentCam_Planet in Program.IPSLibrary.app.core.IPSComponent.IPSComponentCam (File=C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentCam\IPSComponentCam_Planet.class.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:12.16 Created Script IPSComponentCam_Planet=40478
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:54:12.17 Register Script IPSComponentCam_Vivotek in Program.IPSLibrary.app.core.IPSComponent.IPSComponentCam (File=C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentCam\IPSComponentCam_Vivotek.class.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:12.17 Created Script IPSComponentCam_Vivotek=12378
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:54:12.17 Register Script IPSComponentCam_YCam in Program.IPSLibrary.app.core.IPSComponent.IPSComponentCam (File=C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentCam\IPSComponentCam_YCam.class.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:12.17 Created Script IPSComponentCam_YCam=44510
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:54:12.17 Register Script IPSComponentPlayer in Program.IPSLibrary.app.core.IPSComponent.IPSComponentPlayer (File=C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentPlayer\IPSComponentPlayer.class.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:12.18 Created Category IPSComponentPlayer=42748
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:12.18 Created Script IPSComponentPlayer=54558
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:54:12.18 Register Script IPSComponentPlayer_Sonos in Program.IPSLibrary.app.core.IPSComponent.IPSComponentPlayer (File=C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentPlayer\IPSComponentPlayer_Sonos.class.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:12.18 Created Script IPSComponentPlayer_Sonos=43564
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:54:12.18 Register Script IPSComponentPlayer_Mediaplayer in Program.IPSLibrary.app.core.IPSComponent.IPSComponentPlayer (File=C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentPlayer\IPSComponentPlayer_Mediaplayer.class.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:12.19 Created Script IPSComponentPlayer_Mediaplayer=37260
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:54:12.19 Register Script IPSComponentPlayer_Squeezebox in Program.IPSLibrary.app.core.IPSComponent.IPSComponentPlayer (File=C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentPlayer\IPSComponentPlayer_Squeezebox.class.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:12.19 Created Script IPSComponentPlayer_Squeezebox=51191
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:54:12.19 Register Script IPSModulePlayer in Program.IPSLibrary.app.core.IPSComponent.IPSComponentPlayer (File=C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentPlayer\IPSModulePlayer.class.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:12.20 Created Script IPSModulePlayer=24423
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:54:12.20 Register Script IPSModulePlayer_NetPlayer in Program.IPSLibrary.app.core.IPSComponent.IPSComponentPlayer (File=C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentPlayer\IPSModulePlayer_NetPlayer.class.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:12.20 Created Script IPSModulePlayer_NetPlayer=54100
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:54:12.20 Register Script IPSComponentShutter in Program.IPSLibrary.app.core.IPSComponent.IPSComponentShutter (File=C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentShutter\IPSComponentShutter.class.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:12.20 Created Category IPSComponentShutter=56254
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:12.21 Created Script IPSComponentShutter=33502
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:54:12.21 Register Script IPSComponentShutter_Homematic in Program.IPSLibrary.app.core.IPSComponent.IPSComponentShutter (File=C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentShutter\IPSComponentShutter_Homematic.class.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:12.21 Created Script IPSComponentShutter_Homematic=50618
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:54:12.21 Register Script IPSComponentShutter_Dummy in Program.IPSLibrary.app.core.IPSComponent.IPSComponentShutter (File=C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentShutter\IPSComponentShutter_Dummy.class.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:12.22 Created Script IPSComponentShutter_Dummy=43078
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:54:12.22 Register Script IPSComponentShutter_1Wire in Program.IPSLibrary.app.core.IPSComponent.IPSComponentShutter (File=C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentShutter\IPSComponentShutter_1Wire.class.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:12.22 Created Script IPSComponentShutter_1Wire=19375
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:54:12.22 Register Script IPSComponentShutter_Enocean in Program.IPSLibrary.app.core.IPSComponent.IPSComponentShutter (File=C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentShutter\IPSComponentShutter_Enocean.class.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:12.24 Created Script IPSComponentShutter_Enocean=27309
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:54:12.24 Register Script IPSComponentShutter_FS20 in Program.IPSLibrary.app.core.IPSComponent.IPSComponentShutter (File=C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentShutter\IPSComponentShutter_FS20.class.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:12.25 Created Script IPSComponentShutter_FS20=47388
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:54:12.25 Register Script IPSComponentShutter_IPSShutterControl in Program.IPSLibrary.app.core.IPSComponent.IPSComponentShutter (File=C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentShutter\IPSComponentShutter_IPSShutterControl.class.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:12.25 Created Script IPSComponentShutter_IPSShutterControl=51922
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:54:12.25 Register Script IPSComponentShutter_LCN in Program.IPSLibrary.app.core.IPSComponent.IPSComponentShutter (File=C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentShutter\IPSComponentShutter_LCN.class.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:12.26 Created Script IPSComponentShutter_LCN=19638
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:54:12.26 Register Script IPSComponentShutter_EIB in Program.IPSLibrary.app.core.IPSComponent.IPSComponentShutter (File=C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentShutter\IPSComponentShutter_EIB.class.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:12.26 Created Script IPSComponentShutter_EIB=16417
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:54:12.26 Register Script IPSComponentShutter_MoellerEaton in Program.IPSLibrary.app.core.IPSComponent.IPSComponentShutter (File=C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentShutter\IPSComponentShutter_MoellerEaton.class.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:12.26 Created Script IPSComponentShutter_MoellerEaton=16713
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:54:12.27 Register Script IPSComponentShutter_zwave in Program.IPSLibrary.app.core.IPSComponent.IPSComponentShutter (File=C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentShutter\IPSComponentShutter_zwave.class.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:12.27 Created Script IPSComponentShutter_zwave=42323
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:54:12.27 Register Script IPSModuleShutter in Program.IPSLibrary.app.core.IPSComponent.IPSComponentShutter (File=C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentShutter\IPSModuleShutter.class.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:12.27 Created Script IPSModuleShutter=13422
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:54:12.28 Register Script IPSModuleShutter_IPSShadowing in Program.IPSLibrary.app.core.IPSComponent.IPSComponentShutter (File=C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentShutter\IPSModuleShutter_IPSShadowing.class.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:12.28 Created Script IPSModuleShutter_IPSShadowing=57551
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:54:12.28 Register Script IPSComponentSwitch in Program.IPSLibrary.app.core.IPSComponent.IPSComponentSwitch (File=C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentSwitch\IPSComponentSwitch.class.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:12.28 Created Category IPSComponentSwitch=53503
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:12.28 Created Script IPSComponentSwitch=32409
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:54:12.29 Register Script IPSComponentSwitch_1WireD2408 in Program.IPSLibrary.app.core.IPSComponent.IPSComponentSwitch (File=C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentSwitch\IPSComponentSwitch_1WireD2408.class.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:12.29 Created Script IPSComponentSwitch_1WireD2408=46390
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:54:12.29 Register Script IPSComponentSwitch_1WireD2413 in Program.IPSLibrary.app.core.IPSComponent.IPSComponentSwitch (File=C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentSwitch\IPSComponentSwitch_1WireD2413.class.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:12.29 Created Script IPSComponentSwitch_1WireD2413=43778
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:54:12.29 Register Script IPSComponentSwitch_Dummy in Program.IPSLibrary.app.core.IPSComponent.IPSComponentSwitch (File=C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentSwitch\IPSComponentSwitch_Dummy.class.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:12.30 Created Script IPSComponentSwitch_Dummy=34653
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:54:12.30 Register Script IPSComponentSwitch_EatonMoeller in Program.IPSLibrary.app.core.IPSComponent.IPSComponentSwitch (File=C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentSwitch\IPSComponentSwitch_EatonMoeller.class.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:12.30 Created Script IPSComponentSwitch_EatonMoeller=51423
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:54:12.30 Register Script IPSComponentSwitch_EIB in Program.IPSLibrary.app.core.IPSComponent.IPSComponentSwitch (File=C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentSwitch\IPSComponentSwitch_EIB.class.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:12.31 Created Script IPSComponentSwitch_EIB=25214
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:54:12.31 Register Script IPSComponentSwitch_FS20 in Program.IPSLibrary.app.core.IPSComponent.IPSComponentSwitch (File=C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentSwitch\IPSComponentSwitch_FS20.class.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:12.31 Created Script IPSComponentSwitch_FS20=47839
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:54:12.31 Register Script IPSComponentSwitch_Homematic in Program.IPSLibrary.app.core.IPSComponent.IPSComponentSwitch (File=C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentSwitch\IPSComponentSwitch_Homematic.class.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:12.32 Created Script IPSComponentSwitch_Homematic=57029
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:54:12.32 Register Script IPSComponentSwitch_ModBus in Program.IPSLibrary.app.core.IPSComponent.IPSComponentSwitch (File=C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentSwitch\IPSComponentSwitch_ModBus.class.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:12.32 Created Script IPSComponentSwitch_ModBus=38204
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:54:12.32 Register Script IPSComponentSwitch_LCN in Program.IPSLibrary.app.core.IPSComponent.IPSComponentSwitch (File=C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentSwitch\IPSComponentSwitch_LCN.class.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:12.33 Created Script IPSComponentSwitch_LCN=56480
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:54:12.33 Register Script IPSComponentSwitch_ZW in Program.IPSLibrary.app.core.IPSComponent.IPSComponentSwitch (File=C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentSwitch\IPSComponentSwitch_ZW.class.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:12.33 Created Script IPSComponentSwitch_ZW=50290
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:54:12.33 Register Script IPSModuleSwitch in Program.IPSLibrary.app.core.IPSComponent.IPSComponentSwitch (File=C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentSwitch\IPSModuleSwitch.class.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:12.34 Created Script IPSModuleSwitch=51032
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:54:12.34 Register Script IPSModuleSwitch_IPSLight in Program.IPSLibrary.app.core.IPSComponent.IPSComponentSwitch (File=C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentSwitch\IPSModuleSwitch_IPSLight.class.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:12.34 Created Script IPSModuleSwitch_IPSLight=19831
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:54:12.34 Register Script IPSComponentDimmer in Program.IPSLibrary.app.core.IPSComponent.IPSComponentDimmer (File=C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentDimmer\IPSComponentDimmer.class.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:12.34 Created Category IPSComponentDimmer=35886
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:12.35 Created Script IPSComponentDimmer=21242
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:54:12.35 Register Script IPSComponentDimmer_Dummy in Program.IPSLibrary.app.core.IPSComponent.IPSComponentDimmer (File=C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentDimmer\IPSComponentDimmer_Dummy.class.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:12.35 Created Script IPSComponentDimmer_Dummy=10543
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:54:12.35 Register Script IPSComponentDimmer_EIB in Program.IPSLibrary.app.core.IPSComponent.IPSComponentDimmer (File=C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentDimmer\IPSComponentDimmer_EIB.class.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:12.36 Created Script IPSComponentDimmer_EIB=19266
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:54:12.36 Register Script IPSComponentDimmer_FS20 in Program.IPSLibrary.app.core.IPSComponent.IPSComponentDimmer (File=C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentDimmer\IPSComponentDimmer_FS20.class.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:12.36 Created Script IPSComponentDimmer_FS20=34746
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:54:12.36 Register Script IPSComponentDimmer_Homematic in Program.IPSLibrary.app.core.IPSComponent.IPSComponentDimmer (File=C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentDimmer\IPSComponentDimmer_Homematic.class.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:12.36 Created Script IPSComponentDimmer_Homematic=35562
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:54:12.37 Register Script IPSComponentDimmer_ZW in Program.IPSLibrary.app.core.IPSComponent.IPSComponentDimmer (File=C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentDimmer\IPSComponentDimmer_ZW.class.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:12.37 Created Script IPSComponentDimmer_ZW=40679
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:54:12.37 Register Script IPSModuleDimmer in Program.IPSLibrary.app.core.IPSComponent.IPSComponentDimmer (File=C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentDimmer\IPSModuleDimmer.class.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:12.37 Created Script IPSModuleDimmer=54445
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:54:12.38 Register Script IPSComponentRGB in Program.IPSLibrary.app.core.IPSComponent.IPSComponentRGB (File=C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentRGB\IPSComponentRGB.class.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:12.38 Created Category IPSComponentRGB=41178
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:12.38 Created Script IPSComponentRGB=14634
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:54:12.38 Register Script IPSComponentRGB_IPS868 in Program.IPSLibrary.app.core.IPSComponent.IPSComponentRGB (File=C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentRGB\IPSComponentRGB_IPS868.class.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:12.39 Created Script IPSComponentRGB_IPS868=38870
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:54:12.39 Register Script IPSComponentRGB_Dummy in Program.IPSLibrary.app.core.IPSComponent.IPSComponentRGB (File=C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentRGB\IPSComponentRGB_Dummy.class.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:12.39 Created Script IPSComponentRGB_Dummy=52347
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:54:12.39 Register Script IPSModuleRGB in Program.IPSLibrary.app.core.IPSComponent.IPSComponentRGB (File=C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentRGB\IPSModuleRGB.class.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:12.39 Created Script IPSModuleRGB=28182
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:54:12.40 Register Script IPSComponentAVControl in Program.IPSLibrary.app.core.IPSComponent.IPSComponentAVControl (File=C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentAVControl\IPSComponentAVControl.class.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:12.40 Created Category IPSComponentAVControl=50246
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:12.40 Created Script IPSComponentAVControl=36096
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:54:12.40 Register Script IPSComponentAVControl_AudioMax in Program.IPSLibrary.app.core.IPSComponent.IPSComponentAVControl (File=C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentAVControl\IPSComponentAVControl_AudioMax.class.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:12.41 Created Script IPSComponentAVControl_AudioMax=15329
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:54:12.41 Register Script IPSModuleAVControl in Program.IPSLibrary.app.core.IPSComponent.IPSComponentAVControl (File=C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentAVControl\IPSModuleAVControl.class.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:12.41 Created Script IPSModuleAVControl=31468
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:54:12.41 Register Script IPSModuleAVControl_Entertainment in Program.IPSLibrary.app.core.IPSComponent.IPSComponentAVControl (File=C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentAVControl\IPSModuleAVControl_Entertainment.class.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:12.41 Created Script IPSModuleAVControl_Entertainment=28564
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:54:12.42 Register Script IPSComponentSensor in Program.IPSLibrary.app.core.IPSComponent.IPSComponentSensor (File=C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentSensor\IPSComponentSensor.class.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:12.42 Created Category IPSComponentSensor=38605
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:12.42 Created Script IPSComponentSensor=38493
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:54:12.42 Register Script IPSComponentSensor_Button in Program.IPSLibrary.app.core.IPSComponent.IPSComponentSensor (File=C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentSensor\IPSComponentSensor_Button.class.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:12.43 Created Script IPSComponentSensor_Button=33536
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:54:12.43 Register Script IPSComponentSensor_IRTrans in Program.IPSLibrary.app.core.IPSComponent.IPSComponentSensor (File=C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentSensor\IPSComponentSensor_IRTrans.class.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:12.43 Created Script IPSComponentSensor_IRTrans=34675
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:54:12.43 Register Script IPSModuleSensor in Program.IPSLibrary.app.core.IPSComponent.IPSComponentSensor (File=C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentSensor\IPSModuleSensor.class.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:12.44 Created Script IPSModuleSensor=22058
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:54:12.44 Register Script IPSModuleSensor_IPSShadowing in Program.IPSLibrary.app.core.IPSComponent.IPSComponentSensor (File=C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentSensor\IPSModuleSensor_IPSShadowing.class.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:12.44 Created Script IPSModuleSensor_IPSShadowing=40058
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:54:12.44 Register Script IPSModuleSensor_IRTrans in Program.IPSLibrary.app.core.IPSComponent.IPSComponentSensor (File=C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentSensor\IPSModuleSensor_IRTrans.class.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:12.44 Created Script IPSModuleSensor_IRTrans=12356
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:54:12.45 Register Script IPSModuleSensor_NetPlayer in Program.IPSLibrary.app.core.IPSComponent.IPSComponentSensor (File=C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentSensor\IPSModuleSensor_NetPlayer.class.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:12.45 Created Script IPSModuleSensor_NetPlayer=30398
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:54:12.45 Register Script IPSModuleSensor_Entertainment in Program.IPSLibrary.app.core.IPSComponent.IPSComponentSensor (File=C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentSensor\IPSModuleSensor_Entertainment.class.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:12.45 Created Script IPSModuleSensor_Entertainment=43171
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:54:12.45 Register Script IPSModuleSensor_IPSLight in Program.IPSLibrary.app.core.IPSComponent.IPSComponentSensor (File=C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSComponent\IPSComponentSensor\IPSModuleSensor_IPSLight.class.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:12.46 Created Script IPSModuleSensor_IPSLight=28878
IPSModuleManager-Log-IPSFileVersionHandle2013-12-17 06:54:12.46 Set Version IPSComponent=2.50.32 (Loaded)
IPSModuleManager-Log-IPSFileVersionHandle2013-12-17 06:54:12.46 Set Version IPSComponent=2.50.1 (Installing)
IPSModuleManager-Log-IPSFileVersionHandle2013-12-17 06:54:12.47 Set Version IPSComponent=2.50.1 (Installed)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:12.47 Module Download Ini File doesnt exists -> Load Ini File „https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary\install\DownloadListFiles\IPSMessageHandler_FileList.ini“
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:54:12.47 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/install/DownloadListFiles/IPSMessageHandler_FileList.ini —> C:\IP-Symcon\scripts\IPSLibrary\install\DownloadListFiles\IPSMessageHandler_FileList.ini
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:13.45 Module Ini File doesnt exists -> Load Default Ini File „C:\IP-Symcon\scripts\IPSLibrary\install\InitializationFiles\Default\IPSMessageHandler.ini“
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:54:13.45 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/install/InitializationFiles/Default/IPSMessageHandler.ini —> C:\IP-Symcon\scripts\IPSLibrary\install\InitializationFiles\Default\IPSMessageHandler.ini
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:54:14.11 Create User File C:\IP-Symcon\scripts\IPSLibrary\install\InitializationFiles\IPSMessageHandler.ini from Default File C:\IP-Symcon\scripts\IPSLibrary\install\InitializationFiles\Default\IPSMessageHandler.ini
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:54:14.11 Copy C:\IP-Symcon\scripts\IPSLibrary\install\InitializationFiles\Default\IPSMessageHandler.ini --> C:\IP-Symcon\scripts\IPSLibrary\install\InitializationFiles\IPSMessageHandler.ini
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:54:14.11 Create Directory C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-17_0654\IPSLibrary\install\DownloadListFiles
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:54:14.16 Copy C:\IP-Symcon\scripts\IPSLibrary\install\DownloadListFiles\IPSMessageHandler_FileList.ini --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-17_0654\IPSLibrary\install\DownloadListFiles\IPSMessageHandler_FileList.ini
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:54:14.16 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/install/DownloadListFiles/IPSMessageHandler_FileList.ini —> C:\IP-Symcon\scripts\IPSLibrary\install\DownloadListFiles\IPSMessageHandler_FileList.ini
IPSModuleManager-Log-IPSFileVersionHandle2013-12-17 06:54:15.06 Set Version IPSMessageHandler=2.50.6 (Loading)
IPSModuleManager-Log-IPSFileVersionHandle2013-12-17 06:54:15.06 Set Repository IPSMessageHandler=https://raw.github.com/brownson/IPSLibrary/Development/
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:54:15.07 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\install\InstallationScripts\IPSMessageHandler_Installation.ips.php doesnt exists
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:54:15.07 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/install/InstallationScripts/IPSMessageHandler_Installation.ips.php —> C:\IP-Symcon\scripts\IPSLibrary\install\InstallationScripts\IPSMessageHandler_Installation.ips.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:54:15.96 Create Directory C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-17_0654\IPSLibrary\install\InitializationFiles\Default
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:54:15.96 Copy C:\IP-Symcon\scripts\IPSLibrary\install\InitializationFiles\Default\IPSMessageHandler.ini --> C:\IP-Symcon\backup\IPSLibrary_Load\IPSLibrary_2013-12-17_0654\IPSLibrary\install\InitializationFiles\Default\IPSMessageHandler.ini
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:54:15.97 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/install/InitializationFiles/Default/IPSMessageHandler.ini —> C:\IP-Symcon\scripts\IPSLibrary\install\InitializationFiles\Default\IPSMessageHandler.ini
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:54:16.55 Register Script IPSMessageHandler.ini in Program.IPSLibrary.install.InitializationFiles (File=C:\IP-Symcon\scripts\IPSLibrary\install\InitializationFiles\IPSMessageHandler.ini)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:16.55 Created Script IPSMessageHandler.ini=25838
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:54:16.55 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSMessageHandler\IPSMessageHandler.class.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:54:16.56 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSMessageHandler\IPSMessageHandler_Event.ips.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:54:16.56 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSMessageHandler\IPSMessageHandler_IREvent.ips.php doesnt exists
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:54:16.56 Create Directory C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSMessageHandler
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:54:16.56 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSMessageHandler/IPSMessageHandler.class.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSMessageHandler\IPSMessageHandler.class.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:54:17.94 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSMessageHandler/IPSMessageHandler_Event.ips.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSMessageHandler\IPSMessageHandler_Event.ips.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:54:18.54 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/app/core/IPSMessageHandler/IPSMessageHandler_IREvent.ips.php —> C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSMessageHandler\IPSMessageHandler_IREvent.ips.php
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:54:19.20 Register Script IPSMessageHandler in Program.IPSLibrary.app.core.IPSMessageHandler (File=C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSMessageHandler\IPSMessageHandler.class.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:19.20 Created Category IPSMessageHandler=11282
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:19.20 Created Script IPSMessageHandler=46160
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:54:19.20 Register Script IPSMessageHandler_Event in Program.IPSLibrary.app.core.IPSMessageHandler (File=C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSMessageHandler\IPSMessageHandler_Event.ips.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:19.21 Created Script IPSMessageHandler_Event=45868
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:54:19.21 Register Script IPSMessageHandler_IREvent in Program.IPSLibrary.app.core.IPSMessageHandler (File=C:\IP-Symcon\scripts\IPSLibrary\app\core\IPSMessageHandler\IPSMessageHandler_IREvent.ips.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:19.21 Created Script IPSMessageHandler_IREvent=15871
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:54:19.21 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\config\core\IPSMessageHandler\Default\IPSMessageHandler_Configuration.inc.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:54:19.21 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\config\core\IPSMessageHandler\Default\IPSMessageHandler_Custom.inc.php doesnt exists
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:54:19.21 Create Directory C:\IP-Symcon\scripts\IPSLibrary\config\core\IPSMessageHandler\Default
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:54:19.22 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/config/core/IPSMessageHandler/Default/IPSMessageHandler_Configuration.inc.php —> C:\IP-Symcon\scripts\IPSLibrary\config\core\IPSMessageHandler\Default\IPSMessageHandler_Configuration.inc.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:54:20.21 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/config/core/IPSMessageHandler/Default/IPSMessageHandler_Custom.inc.php —> C:\IP-Symcon\scripts\IPSLibrary\config\core\IPSMessageHandler\Default\IPSMessageHandler_Custom.inc.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:54:21.47 Create User File C:\IP-Symcon\scripts\IPSLibrary\config\core\IPSMessageHandler\IPSMessageHandler_Configuration.inc.php from Default File C:\IP-Symcon\scripts\IPSLibrary\config\core\IPSMessageHandler\Default\IPSMessageHandler_Configuration.inc.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:54:21.47 Copy C:\IP-Symcon\scripts\IPSLibrary\config\core\IPSMessageHandler\Default\IPSMessageHandler_Configuration.inc.php --> C:\IP-Symcon\scripts\IPSLibrary\config\core\IPSMessageHandler\IPSMessageHandler_Configuration.inc.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:54:21.47 Create User File C:\IP-Symcon\scripts\IPSLibrary\config\core\IPSMessageHandler\IPSMessageHandler_Custom.inc.php from Default File C:\IP-Symcon\scripts\IPSLibrary\config\core\IPSMessageHandler\Default\IPSMessageHandler_Custom.inc.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:54:21.48 Copy C:\IP-Symcon\scripts\IPSLibrary\config\core\IPSMessageHandler\Default\IPSMessageHandler_Custom.inc.php --> C:\IP-Symcon\scripts\IPSLibrary\config\core\IPSMessageHandler\IPSMessageHandler_Custom.inc.php
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:54:21.48 Register Script IPSMessageHandler_Configuration in Program.IPSLibrary.config.core.IPSMessageHandler (File=C:\IP-Symcon\scripts\IPSLibrary\config\core\IPSMessageHandler\IPSMessageHandler_Configuration.inc.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:21.48 Created Category IPSMessageHandler=10377
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:21.49 Created Script IPSMessageHandler_Configuration=53690
IPSModuleManager-Log-IPSScriptHandler 2013-12-17 06:54:21.49 Register Script IPSMessageHandler_Custom in Program.IPSLibrary.config.core.IPSMessageHandler (File=C:\IP-Symcon\scripts\IPSLibrary\config\core\IPSMessageHandler\IPSMessageHandler_Custom.inc.php)
IPSModuleManager-Log-IPSModuleManager 2013-12-17 06:54:21.49 Created Script IPSMessageHandler_Custom=28443
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:54:21.49 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\config\core\IPSMessageHandler\Examples\IPSMessageHandler_Configuration.inc.php doesnt exists
IPSModuleManager-Log-IPSBackupHandler 2013-12-17 06:54:21.49 Backup NOT possible - Source File C:\IP-Symcon\scripts\IPSLibrary\config\core\IPSMessageHandler\Examples\IPSMessageHandler_Custom.inc.php doesnt exists
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:54:21.49 Create Directory C:\IP-Symcon\scripts\IPSLibrary\config\core\IPSMessageHandler\Examples
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:54:21.49 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/config/core/IPSMessageHandler/Examples/IPSMessageHandler_Configuration.inc.php —> C:\IP-Symcon\scripts\IPSLibrary\config\core\IPSMessageHandler\Examples\IPSMessageHandler_Configuration.inc.php
IPSModuleManager-Log-IPSFileHandler 2013-12-17 06:54:22.75 Copy https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/config/core/IPSMessageHandler/Examples/IPSMessageHandler_Custom.inc.php —> C:\IP-Symcon\scripts\IPSLibrary\config\core\IPSMessageHandler\Examples\IPSMessageHandler_Custom.inc.php
IPSModuleManager-Log-IPSFileVersionHandle2013-12-17 06:54:23.78 Set Version IPSMessageHandler=2.50.6 (Loaded)
IPSModuleManager-Log-IPSFileVersionHandle2013-12-17 06:54:23.78 Set Version IPSMessageHandler=2.50.1 (Installing)
IPSModuleManager-Log-IPSFileVersionHandle2013-12-17 06:54:23.79 Set Version IPSMessageHandler=2.50.1 (Installed)
Wenn ich dann das Webfront aufrufe bekomme ich folgendes Bild (siehe Screenshot 1)
Kann mir jemand sagen, was ich da falsch mache?
Danke im voraus und sehr mir meine Anfängerfehler nach.
