OKay Version 1080 läuft durch, aber im WEBFRONT wird nix angelegt - unter „Visualization“ allerdings schon.
Oder soll ich per Webfront nochmal alles deinstallieren und NEU?
IPSModuleManager-Log-IPSFileVersionHandler 2015-12-26 15:35:49.04 Set Version Plugwise=1.2.1080 (Installing)
IPSModuleManager-Log-IPSModuleManager 2015-12-26 15:35:49.07 Empty Category ID=28901
IPSModuleManager-Log-IPSModuleManager 2015-12-26 15:35:49.07 Empty Category ID=38529
IPSModuleManager-Log-IPSModuleManager 2015-12-26 15:35:49.07 Empty Category ID=34363
IPSModuleManager-Log-IPSModuleManager 2015-12-26 15:35:49.07 Empty Category ID=39138
IPSModuleManager-Log-IPSModuleManager 2015-12-26 15:35:49.07 Empty Category ID=27059
IPSModuleManager-Log-IPSModuleManager 2015-12-26 15:35:49.07 Delete Category ID=27059
IPSModuleManager-Log-IPSModuleManager 2015-12-26 15:35:49.07 Empty Category ID=31045
IPSModuleManager-Log-IPSModuleManager 2015-12-26 15:35:49.07 Delete Category ID=31045
IPSModuleManager-Log-IPSModuleManager 2015-12-26 15:35:49.07 Empty Category ID=45822
IPSModuleManager-Log-IPSModuleManager 2015-12-26 15:35:49.07 Delete Category ID=45822
IPSModuleManager-Log-IPSModuleManager 2015-12-26 15:35:49.07 Empty Category ID=30917
IPSModuleManager-Log-IPSModuleManager 2015-12-26 15:35:49.07 Delete Category ID=30917
IPSModuleManager-Log-IPSModuleManager 2015-12-26 15:35:49.07 Empty Category ID=18432
IPSModuleManager-Log-IPSModuleManager 2015-12-26 15:35:49.07 Delete Category ID=18432
IPSModuleManager-Log-IPSModuleManager 2015-12-26 15:35:49.07 Empty Category ID=58865
IPSModuleManager-Log-IPSModuleManager 2015-12-26 15:35:49.07 Delete Category ID=58865
IPSModuleManager-Log-IPSModuleManager 2015-12-26 15:35:49.07 Empty Category ID=52229
IPSModuleManager-Log-IPSModuleManager 2015-12-26 15:35:49.07 Empty Category ID=29178
IPSModuleManager-Log-IPSModuleManager 2015-12-26 15:35:49.08 Set VariableCustomAction='' for Variable='Status'
IPSModuleManager-Log-IPSModuleManager 2015-12-26 15:35:49.46 Set VariableCustomAction='' for Variable='Status'
IPSModuleManager-Log-IPSModuleManager 2015-12-26 15:35:50.59 Delete WFC Item='IPSLibraryPlugwise'
IPSModuleManager-Log-IPSModuleManager 2015-12-26 15:35:50.59 Delete WFC Item='IPSLibraryPlugwise-MENU'
IPSModuleManager-Log-IPSModuleManager 2015-12-26 15:35:50.60 Delete WFC Item='IPSLibraryPlugwise-SPLITPANEMAIN'
IPSModuleManager-Log-IPSModuleManager 2015-12-26 15:35:50.60 Delete WFC Item='IPSLibraryPlugwise-SPLITPANESUB'
IPSModuleManager-Log-IPSModuleManager 2015-12-26 15:35:50.60 Delete WFC Item='IPSLibraryPlugwiseDATA1'
IPSModuleManager-Log-IPSModuleManager 2015-12-26 15:35:50.60 Delete WFC Item='IPSLibraryPlugwiseDATA2'
IPSModuleManager-Log-IPSModuleManager 2015-12-26 15:35:50.60 Delete WFC Item='IPSLibraryPlugwiseGRAPH'
IPSModuleManager-Log-IPSModuleManager 2015-12-26 15:35:50.60 Created Category MENU=20197
IPSModuleManager-Log-IPSModuleManager 2015-12-26 15:35:50.60 Created Category DATA=21637
IPSModuleManager-Log-IPSModuleManager 2015-12-26 15:35:50.60 Created Category DATA1=11392
IPSModuleManager-Log-IPSModuleManager 2015-12-26 15:35:50.60 Created Category DATA2=20234
IPSModuleManager-Log-IPSModuleManager 2015-12-26 15:35:50.60 Created Category GRAPH=14446
IPSModuleManager-Log-IPSModuleManager 2015-12-26 15:35:50.60 Created Category Highcharts=35823
IPSModuleManager-Log-IPSModuleManager 2015-12-26 15:35:50.60 Created VariableId WEBDATA1=44637
IPSModuleManager-Log-IPSModuleManager 2015-12-26 15:35:50.60 Created VariableId WEBDATA2=33353
IPSModuleManager-Log-IPSModuleManager 2015-12-26 15:35:50.60 Created VariableId WEBDATA=27238
IPSModuleManager-Log-IPSModuleManager 2015-12-26 15:35:50.60 Created VariableId StartTime=19213
IPSModuleManager-Log-IPSModuleManager 2015-12-26 15:35:50.60 Set VariableCustomAction='1451054150' for Variable='StartTime'
IPSModuleManager-Log-IPSModuleManager 2015-12-26 15:35:50.60 Created VariableId EndTime=14287
IPSModuleManager-Log-IPSModuleManager 2015-12-26 15:35:50.60 Set VariableCustomAction='1451140550' for Variable='EndTime'
IPSModuleManager-Log-IPSModuleManager 2015-12-26 15:35:50.60 Created VariableId Now=27715
IPSModuleManager-Log-IPSModuleManager 2015-12-26 15:35:50.61 Created VariableId Uebersicht=12627
IPSModuleManager-Log-IPSModuleManager 2015-12-26 15:35:50.61 Created VariableId Auswahl=17712
IPSModuleManager-Log-IPSModuleManager 2015-12-26 15:35:50.61 Created Instance Allgemeines=38793, ModuleID={485D0419-BE97-4548-AA9C-C083EB82E61E}
IPSModuleManager-Log-IPSModuleManager 2015-12-26 15:35:50.61 Created Instance Gruppen=16742, ModuleID={485D0419-BE97-4548-AA9C-C083EB82E61E}
IPSModuleManager-Log-IPSModuleManager 2015-12-26 15:35:50.61 Created Instance Stromzaehler=10560, ModuleID={485D0419-BE97-4548-AA9C-C083EB82E61E}
IPSModuleManager-Log-IPSModuleManager 2015-12-26 15:35:50.61 Created Instance Systemsteuerung=24196, ModuleID={485D0419-BE97-4548-AA9C-C083EB82E61E}
IPSModuleManager-Log-IPSModuleManager 2015-12-26 15:35:50.61 Created VariableId Webfront=42807
IPSModuleManager-Log-IPSModuleManager 2015-12-26 15:35:50.61 Add WFCItem='IPSLibraryPlugwise', Class=SplitPane, Config={"title":"Plugwise","name":"IPSLibraryPlugwise","icon":"Lightning","alignmentType":1,"ratio":30,"ratioTarget":0,"ratioType":0,"showBorder":true}
IPSModuleManager-Log-IPSModuleManager 2015-12-26 15:35:50.61 Add WFCItem='IPSLibraryPlugwise-MENU', Class=Category, Config={"title":"Titel","name":"IPSLibraryPlugwise-MENU","icon":"","baseID":20197,"enumBarColumns":9,"selectorBarSteps":5,"isBarBottomVisible":true,"enablePercentageSlider":true}
IPSModuleManager-Log-IPSModuleManager 2015-12-26 15:35:50.61 Add WFCItem='IPSLibraryPlugwise-SPLITPANEMAIN', Class=SplitPane, Config={"title":"Plugwise","name":"IPSLibraryPlugwise-SPLITPANEMAIN","icon":"Lightning","alignmentType":0,"ratio":30,"ratioTarget":0,"ratioType":0,"showBorder":false}
IPSModuleManager-Log-IPSModuleManager 2015-12-26 15:35:50.61 Add WFCItem='IPSLibraryPlugwise-SPLITPANESUB', Class=SplitPane, Config={"title":"Plugwise","name":"IPSLibraryPlugwise-SPLITPANESUB","icon":"Lightning","alignmentType":1,"ratio":50,"ratioTarget":0,"ratioType":0,"showBorder":false}
IPSModuleManager-Log-IPSModuleManager 2015-12-26 15:35:50.62 Add WFCItem='IPSLibraryPlugwiseDATA1', Class=ContentChanger, Config={"title":"Info","name":"IPSLibraryPlugwiseInfo","baseID":44637,"icon":"Information","showBorder":false}
IPSModuleManager-Log-IPSModuleManager 2015-12-26 15:35:50.62 Add WFCItem='IPSLibraryPlugwiseDATA2', Class=ContentChanger, Config={"title":"Info","name":"IPSLibraryPlugwiseInfo","baseID":33353,"icon":"Information","showBorder":false}
IPSModuleManager-Log-IPSModuleManager 2015-12-26 15:35:50.62 Add WFCItem='IPSLibraryPlugwiseGRAPH', Class=ContentChanger, Config={"title":"Info","name":"IPSLibraryPlugwiseInfo","baseID":12627,"icon":"Information","showBorder":false}
IPSModuleManager-Log-IPSModuleManager 2015-12-26 15:35:50.62 Created VariableId Systemsteuerung=41701
IPSModuleManager-Log-IPSModuleManager 2015-12-26 15:35:50.62 Created VariableId Antwortzeiten=38067
IPSModuleManager-Log-IPSModuleManager 2015-12-26 15:35:50.62 Created VariableId Raum1=44397
IPSModuleManager-Log-IPSModuleManager 2015-12-26 15:35:50.62 Created VariableId Raum2=50302
IPSModuleManager-Log-IPSModuleManager 2015-12-26 15:35:50.62 Created VariableId Sonstige=43521
IPSModuleManager-Log-IPSModuleManager 2015-12-26 15:35:50.62 Created VariableId Verbraucher1=54352
IPSModuleManager-Log-IPSModuleManager 2015-12-26 15:35:50.62 Created VariableId Verbraucher2=50560
IPSModuleManager-Log-IPSModuleManager 2015-12-26 15:35:50.62 Created VariableId Verbraucher3=23586
IPSModuleManager-Log-IPSModuleManager 2015-12-26 15:35:50.62 Created VariableId Verbraucher4=40210
IPSModuleManager-Log-IPSModuleManager 2015-12-26 15:35:50.62 Created VariableId Kalibrierung=24542
IPSModuleManager-Log-IPSModuleManager 2015-12-26 15:35:50.63 Created VariableId Circles suchen=46066
IPSModuleManager-Log-IPSModuleManager 2015-12-26 15:35:50.63 Created VariableId Circlezeit setzen=14069
IPSModuleManager-Log-IPSModuleManager 2015-12-26 15:35:50.63 Created VariableId OnlineUpdate=18154
IPSModuleManager-Log-IPSModuleManager 2015-12-26 15:35:50.63 Created VariableId Versionsinfo=40924
IPSModuleManager-Log-IPSModuleManager 2015-12-26 15:35:50.63 Created VariableId Update vorhanden?=21438
IPSModuleManager-Log-IPSModuleManager 2015-12-26 15:35:50.63 Created Link Verbraucher1=31021
IPSModuleManager-Log-IPSModuleManager 2015-12-26 15:35:50.63 Created Link Verbraucher2=38698
IPSModuleManager-Log-IPSModuleManager 2015-12-26 15:35:50.63 Created Link Verbraucher3=24863
IPSModuleManager-Log-IPSModuleManager 2015-12-26 15:35:50.63 Created Link Verbraucher4=36439
IPSModuleManager-Log-IPSModuleManager 2015-12-26 15:35:50.63 Created Timer REFRESH=35176
IPSModuleManager-Log-IPSFileVersionHandler 2015-12-26 15:35:50.63 Set Version Plugwise=1.2.1080 (Installed)
