$location = IPS_GetLocation (IPS_GetParent ($_IPS['SELF']));
$ALL_EVENTS = IPS_GetEventList ( );
foreach ($ALL_EVENTS as $key => $value)
$Pfad = " ".IPS_GetLocation ($value);
if(strpos ($Pfad,$location) != 0)
if(IPS_GetObject ($value)['ObjectType'] == 4)//Event
if(IPS_GetEvent ($value)['EventActive'])
IPS_SetEventActive ($value,false);
else
IPS_SetEventActive ($value,true);
else
else
$TestTimestamp = strtotime("23.09.2015");
$Ausgabe = EN_DE_Date_Umwandler("D j. M Y", $TestTimestamp);
echo $Ausgabe;
function EN_DE_Date_Umwandler($DateSyntax, $Timestamp) {
$trans = array(
'Monday' => 'Montag',
'Tuesday' => 'Dienstag',
'Wednesday' => 'Mittwoch',
'Thursday' => 'Donnerstag',
'Friday' => 'Freitag',
'Saturday' => 'Samstag',
'Sunday' => 'Sonntag',
'Mon' => 'Mo',
'Tue' => 'Di',
'Wed' => 'Mi',
'Thu' => 'Do',
'Fri' => 'Fr',
'Sat' => 'Sa',
'Sun' => 'So',
'January' => 'Januar',
'February' => 'Februar',
'March' => 'März',
'May' => 'Mai',
'June' => 'Juni',
'July' => 'Juli',
'October' => 'Oktober',
'December' => 'Dezember'
$DEdate = strtr(date($DateSyntax, $Timestamp), $trans);
return $DEdate;
// Beispiel um das Datum von jedem 2. Montag ausgeben lassen
$TagX = "Montag"; // Montag wird gesucht
$IntervallX = 2; // Jeder 2.
$Jahr = 2015; // Im Jahr 2015
$Counter = 1;
for ($MonatC = 1; $MonatC <= 12; $MonatC++) {
$MonatTage = date("t", strtotime("01.$MonatC.$Jahr"));
for ($TageC = 1; $TageC <= $MonatTage; $TageC++) {
$Wochentag = EN_DE_Date_Umwandler("l", strtotime("$TageC.$MonatC.$Jahr"));
if ($Wochentag == $TagX) {
if ($Counter == $IntervallX) {
$DatumAR[] = EN_DE_Date_Umwandler("d.m.Y", strtotime("$TageC.$MonatC.$Jahr"));
$Counter = 1;
else {
$Counter++;
// AUSGABE DES ARRAY
print_r($DatumAR);
// AUSGABE EINZELN
foreach ($DatumAR as $DatumA) {
echo $DatumA.PHP_EOL;
$trans = array(
'Mon' => 'Mo',
'Tue' => 'Di',
'Wed' => 'Mi',
'Thu' => 'Do',
'Fri' => 'Fr',
'Sat' => 'Sa',
'Sun' => 'So',
'March' => 'März',
'May' => 'Mai',
'June' => 'Juni',
'July' => 'Juli',
return $DEdate;
// Beispiel um das Datum von jedem 2. Montag PRO MONAT ausgeben lassen
$Counter = 1;
$Counter = 1;
else {
$Counter++;
$Counter = 1;
print_r($DatumAR);
// AUSGABE EINZELN
$trans = array(
'Mon' => 'Mo',
'Tue' => 'Di',
'Wed' => 'Mi',
'Thu' => 'Do',
'Fri' => 'Fr',
'Sat' => 'Sa',
'Sun' => 'So',
'March' => 'März',
'May' => 'Mai',
'June' => 'Juni',
'July' => 'Juli',
return $DEdate;
// Zeigt an, wann der Computer zuletzt gestartet wurde. Getestet unter Win7 und Win10
$uptime = IPS_Execute('cmd /c net statistics server | find /i "Statistik seit"', "", false, true);
preg_match('|seit(.*)|', $uptime, $matchuptime);
$uptime = substr($matchuptime[1], 1, -1);
echo "Server online seit: $uptime";
Quelle: Archivkontrolle (by Nall chan)
Skript zum Löschen aller verwaisten Archiv-Einträge. Es werden alle Einträge aus dem Archiv gelöscht, wovon keine zugehörigen Variablen mehr existieren. Diese sind im Archiv meisten daran zu erkennen >> „Objekt #12345 existiert nicht“
Sollte die VariablenID in der Zwischenzeit neu vergeben worden sein, dann wird nichts gelöscht und man hat sich das Logging versaut Wurde die ID an ein Skript oder ein anderes Objekt vergeben, dann wird dieser Name auch im Archiv angezeigt und fällt weniger auf, wird aber dann durch dieses entfernt.
Einfach das Skript unten einmal ausführen, dann wird einem angezeigt was gelöscht werden würden. Braucht man die alten Archiveinträge nicht mehr, dann kann man die Variable $Testlauf auf FALSE setzen und nach ein paar Sekunden/Minuten (je nach Anzahl) sind alle verwaisten Einträge weg
ini_set("max_execution_time", 600);
$Testlauf = true; // Variable auf FALSE setzen, dann werden die Variablen wirklich aus dem Archiv gelöscht. Bei TRUE werden die Variablen-IDs nur angezeigt/ausgegeben, aber es wird nichts gelöscht!
$VarCount = 0;
$VarCountX = 0;
$AC_ID = IPS_GetInstanceListByModuleID('{43192F0B-135B-4CE7-A0A7-1475603F3060}')[0];
$LoggedVarIDs = AC_GetAggregationVariables($AC_ID, true);
foreach ($LoggedVarIDs as $VarID)
if (!IPS_VariableExists($VarID['VariableID'])) {
$VarCount++;
if ($Testlauf == true) {
echo "INFO - Variable mit ID ".$VarID['VariableID']." existiert nicht!".PHP_EOL;
else {
$deleted = AC_DeleteVariableData($AC_ID,$VarID['VariableID'],$VarID['FirstTime'],$VarID['LastTime']);
if ($deleted !== true) {
echo "FEHLER - Konnte Variable mit ID ".$VarID['VariableID']." nicht löschen!".PHP_EOL;
$VarCountX++;
echo "Es wurden $VarCount Archiv-Einträge mit nicht existierenden Variablen gefunden!".PHP_EOL;
else {
echo "Es wurden $VarCount Archiv-Einträge mit nicht existierenden Variablen gelöscht!".PHP_EOL;
echo "Es konnten $VarCountX Archiv-Einträge nicht gelöscht werden!".PHP_EOL;
$Duration = "2:01:03"; // 2 Stunden & 1 Minute & 3 Sekunden
$DurationAR = explode(":", $Duration);
$DurationSTD = (int)$DurationAR[0];
$DurationMIN = (int)$DurationAR[1];
$DurationSEK = (int)$DurationAR[2];
$DurationGesamt = $DurationSEK + ($DurationMIN * 60) + ($DurationSTD * 3600);
echo "$Duration entspricht $DurationGesamt Sekunden";
Umgebung:
Wirksystem unter Windows mit IPS 3.4, auf dem Skripte erstellt werden.
Ein oder mehrere Raspis mit IPS 4.0, auf denen die verwendeten Skripte auf dem neuesten Stand gehalten werden sollen.
Skript:
Das nachfolgende Skript verwendet JSON, deshalb müssen Lizenz-Benutzernamen und das Fernzugriff Kennwort für jedes System zur Verfügung gestellt werden.
Es bietet sich an, diese Informationen in ein eigenes Skript zu schreiben, damit es beliebig in andere Skripte inkludiert werden kann, der Name (hier „ObjIDsLAN.inc.php“ ist bindend, da damit aufgerufen wird).
Für jedes IPS-System existiert ein Index-Eintrag in dem folgendes individuell eingetragen werden muß
- Name des Systems als Index
- ‚IP‘ => IP-Adresse
- ‚PW‘ => Fernzugriff Kennwort
Der Lizenz-Benutzername muß im Index-Eintrag ‚Svr1‘ unter ‚Li‘ eingetragen werden
* File mit Kennwerten des LAN's für Devices.
* @file ObjIDsLAN.inc.php
* @author Harald Hertlein
* @version 21.09.15 00:09
* Remark: OS-unabhängig
$LAN = array (//
'Svr1' => array (
'IP' => '192.168.0.6',
'Port' => '80', // Port unter dem der PC per JSON erreichbar ist
'Li' => 'H?????@??????.de', // Lizenz-Nehmer
'PW' => '?????', // auf dem PC eingestelltes IPS-Paßwort
'IPS' => '3.40;12.08.15;#3775',
'RaspiA1' => array (
'IP' => '192.168.0.81',
'Port' => '3777',
'PW' => '?????',
'IPS' => '4.00;07.10.2015;b3ed15e7',
'RaspiA2' => array (
'IP' => '192.168.0.82',
'Port' => '3777',
'PW' => '????',
'IPS' => '4.00;06.10.2015;43cd1657489d',
In das folgende Arbeitsskript muß dann nur noch der File-Name des zu übertragenden Skriptes und der/die PCs eingetragen werden, zu denen das Skript transferiert werden soll.
* @file IPS2Beitrag_SkriptTransfer.ips.php
* @version 21.10.15 17:03
* Läuft auf dem zentralen Arbeitssystem und transferiert Skripte auf die Raspis
// Definiere erst mal die Parameter (PCs, Skript)
//$PC = 'RaspiA1'; // einer, wenn auskommentiert alle
$Skript = 'IPS2Beitrag_SkriptAgent.ips.php';
$StarteSkript = 1; // wenn gesetzt, wird das Skript auf dem Remote-PC gestartet, sofern es dort benannt wurde
include_once "ObjIDsLAN.inc.php";
if (isset ($PC)) {
$PCs = array ($PC);
} else {
$PCs = array (
'RaspiA1',
'RaspiA2',
foreach ($PCs as $PC) {
$EAObj1 = @IPS_GetScriptIDByFile ($Skript);
if ($EAObj1 === false) {
echo "
Lokales Skript '$Skript' nicht gefunden!";
return;
} else {
echo "
Lokales Skript '$Skript' hat die Objekt-ID " . $EAObj1;
// $rpc = new JSONRPC("http://user:password@'IP':'Port'/api/");
$rpc = new JSONRPC ("http://" . $LAN['Svr1']['Li'] . ':' . $LAN[$PC]['PW'] . '@' . $LAN[$PC]['IP'] . ':' . $LAN[$PC]['Port'] . '/api/');
// $EAObj2 = $rpc -> IPS_GetScriptIDByFile ($Skript); führt bei Nichtexistenz zu einem JSON-Fehler, deshalb
$Liste = $rpc -> IPS_GetScriptList (); // von hinten durch die Brust ins Auge
$EAObj2 = false;
foreach ($Liste as $SkriptID) {
$GetScript = $rpc -> IPS_GetScript ($SkriptID);
if ($GetScript['ScriptFile'] == $Skript) {
$EAObj2 = $GetScript['ScriptID'];
break;
if ($EAObj2 === false) {
echo "
Remotes Skript '$Skript' nicht gefunden!";
$NameOK = false;
$EAObj2 = $rpc -> IPS_CreateScript (0); // Als ObjektName
//$rpc -> IPS_SetName ($EAObj2, substr ($Skript, 0, stripos ($Skript, '.'))); // entweder gekürzten Datei-Namen
$rpc -> IPS_SetName ($EAObj2, $Skript); // oder vollen Datei-Namen (entsprechend auskommentieren)
echo "
Remotes Skript '$Skript' angelegt mit der Objekt-ID " . $EAObj2 . " auf PC '$PC'";
//$rpc -> rename (IPS_GetKernelDir () . 'scripts/' . $EAObj2 . '.ips.php', IPS_GetKernelDir () . 'scripts/' . $Skript); // diese Funktion crashed weil sie rename nicht findet
//$rpc -> IPS_SetScriptFile ($EAObj2, $Skript); // diese Funktion crashed, wenn $Skript nicht vorhanden, deshalb leider
echo "
ACHTUNG!!: Remotes Skript '" . $EAObj2 . ".ips.php' auf PC '$PC' muß umbenannt werden in '$Skript'";
$NameOK = false;
} else {
echo "
Remotes Skript '$Skript' hat die Objekt-ID " . $EAObj2 . " auf PC $PC";
$NameOK = true;
$rpc -> IPS_SetScriptContent ($EAObj2, IPS_GetScriptContent ($EAObj1));
if ($StarteSkript && $NameOK) {
echo " und wird ausgeführt!!";
$Msg = $rpc -> IPS_RunScriptWait ($EAObj2);
print ("
---------- Meldung von PC $PC ---------
$Msg---------------------------------------
Die für IPS zur Verfügung gestellte JSON-RPC API hat den Mangel, dass keine PHP-Befehle per Remote ausgeführt werden können. Wenn das zu transferierende Skript auf dem Ziel-PC noch nicht existiert, kann der File-Name nicht korrekt wiedergegeben werden.
Beim Ersttransfer eines Skriptes muß daher per Konsole auf dem Ziel-PC der File-Name korriegiert werden
Erfolgt dies nicht, wird beim nächsten Update ein neues Skript angelegt.
Existiert der File-Name, wird das entsprechende Skript upgedated.
Man kann sich aber durch das nachfolgende Agenten-Skript „IPS2Beitrag_SkriptAgent.ips.php“ behelfen:
Es wird
- das Agenten-Skript mit dem obigen Skript „IPS2Beitrag_SkriptTransfer.ips.php“ übertragen
- dann entsprechend der Aufforderung des Skriptes (ACHTUNG!!: Remotes Skript … auf PC … muß umbenannt werden ) auf den remoten PCs einmalig umbenennen.
- das Skript „IPS2Beitrag_SkriptTransfer.ips.php“ mit ‚$StarteSkript = 1‘ nochmal ausführen; damit wird/werden die Agenten-Skripte auf den remoten PCs ausgeführt und die darin konfigurierten Kategorien, Variablen, Skripte, Timer, Batchfiles für Linux angelegt.
- die dann noch auf den remoten PCs noch leeren Skripte mit dem obigen Skript „IPS2Beitrag_SkriptTransfer.ips.php“ befüllen (mehrfach mit ‚$StarteSkript = 0‘ und jeweils veränderter Variable $Skript für den Skript-Namen befüllen
* @file IPS2Beitrag_SkriptAgent.ips.php
* Legt verschiedene Komponenten auf einem (remoten) IPS-System an:
* Kategorien
* Variablen
* Skripte
* Timer
* Batchfiles für Linux
$Msg = '';
// ----------------- Konfigurationsanweisungen Start -----
// 1
$KAT = CreateCategory ('Name', 0, 100, 'Ident');
// 1.1
$VIS = CreateVariable ('Variable zur Visualisierung', 3, $KAT, 0, "~HTMLBox", null, '', '', "VIS");
// 1.2
$DTA = CreateVariable ('Variable zur Datenspeicherung', 3, $KAT, 1, "~String", null, '', '', "DTA");
IPS_SetHidden ($DTA, true);
// 1.3
$MON = CreateEmptyScript ('Anzeige-Skript', $KAT, 2, true, 'MON'); // Skript zur Anzeige, Position 2, Hidden
// 1.4
$ACT = CreateEmptyScript ('Ausführungs-Skript', $KAT, 3, true, 'ACT'); // Skript zur Ausführung
// 1.4.1
CreateTimer_CyclicByMinutes('Trigger', $ACT, 8, false); // Timer, noch nicht aktiviert
// 1.4.2 ff
CreateEmptyScript ('Linux', $ACT, 2, false, '', 'sh'); // ein Batchfiles für Linux (Linux.sh)
// ----------------- Konfigurationsanweisungen Ende -----
echo $Msg;
function CreateCategory ($Name, $ParentId = 0, $Position = 0, $ident = "") {
global $Msg;
if ($ident == "")
$ident = Trim_Ident ($Name);
$ObjectId = @IPS_GetObjectIDByIdent ($ident, $ParentId);
if ($ObjectId === false)
$ObjectId = @IPS_GetVariableIDByName ($Name, $ParentId);
if ($ObjectId === false) {
$ObjectId = IPS_CreateCategory ();
IPS_SetName ($ObjectId, $Name);
IPS_SetParent ($ObjectId, $ParentId);
IPS_SetPosition ($ObjectId, $Position);
if ($ident)
IPS_SetIdent ($ObjectId, $ident);
$Msg .= "$ObjectId ist neue Kategory '" . $Name . "' (Ident: " . $ident . ")
return $ObjectId;
/** Quelle IPSInstaller: Anlegen einer Variable (mod.) */
function CreateVariable ($Name, $Type, $ParentId, $Position = 0, $Profile = "", $Action = null, $ValueDefault = '', $Icon = '', $ident = "") {
global $Msg;
if ($ident == "")
$ObjectId = IPS_CreateVariable ($Type);
IPS_SetVariableCustomProfile ($ObjectId, $Profile);
IPS_SetVariableCustomAction ($ObjectId, $Action);
IPS_SetIcon ($ObjectId, $Icon);
SetValue ($ObjectId, $ValueDefault);
$Msg .= "$ObjectId ist neue Variable '" . $Name . "' (Ident: " . $ident . ")
$VariableData = IPS_GetVariable ($ObjectId);
if ($VariableData['VariableCustomProfile'] <> $Profile) {
$Msg .= " VariableProfile '$Profile' für Variable '$Name'
if ($VariableData['VariableCustomAction'] <> $Action) {
$Msg .= " VariableCustomAction '$Action' für Variable '$Name'
UpdateObjectData ($ObjectId, $Position, $Icon);
return $ObjectId;
/** Quelle IPSInstaller: Anlegen eines Scriptes. (mod.) */
function CreateScript ($Name, $File, $ParentId, $Position = 0) {
global $Msg;
$ObjectId = @IPS_GetObjectIDByIdent (Trim_Ident ($Name), $ParentId);
$ObjectId = @IPS_GetScriptIDByName ($Name, $ParentId);
$ObjectId = IPS_CreateScript (0);
IPS_SetIdent ($ObjectId, Trim_Ident ($Name));
if ($File)
IPS_SetScriptFile ($ObjectId, $File);
$Msg .= "$ObjectId ist neues Script '" . $Name . "'
UpdateObjectData ($ObjectId, $Position);
return $ObjectId;
function CreateEmptyScript ($Name, $ParentId, $Position = 0, $Hidden = true, $Ident = '', $Ext = 'ips.php') {
global $Msg;
if (file_exists (IPS_GetKernelDir () . '/scripts/' . $Name . '.' . $Ext)) {
return $ObjectId;
$ObjectId = CreateScript ($Name, '', $ParentId, $Position);
if ($Ident)
IPS_SetIdent ($ObjectId, $Ident);
rename (IPS_GetKernelDir () . '/scripts/' . IPS_GetScript ($ObjectId)['ScriptFile'], IPS_GetKernelDir () . '/scripts/' . $Name . '.' . $Ext);
IPS_SetScriptFile ($ObjectId, $Name . '.' . $Ext);
IPS_SetHidden ($ObjectId, $Hidden);
$Msg .= " $Name.$Ext (Ident: $Ident)
return $ObjectId;
/** Quelle IPSInstaller: Definieren "Minuten" Timer */
function CreateTimer_CyclicByMinutes($Name, $ParentId, $Minutes, $Active = true) {
global $Msg;
$ObjectId = @IPS_GetObjectIDByIdent(Trim_Ident($Name), $ParentId);
$ObjectId = @IPS_GetEventIDByName($Name, $ParentId);
$ObjectId = IPS_CreateEvent(1 /* Cyclic Event */);
IPS_SetName($ObjectId, $Name);
IPS_SetIdent($ObjectId, Trim_Ident($Name));
IPS_SetParent($ObjectId, $ParentId);
if (!IPS_SetEventCyclic($ObjectId, 2 /* Daily */, 1 /* Unused */, 0 /* Unused */, 0/* Unused */, 2/* TimeType Minutes */, $Minutes/* Minutes */)) {
$Msg .= "IPS_SetEventCyclic failed !!!
exit;
IPS_SetEventActive($ObjectId, $Active);
$Msg .= "$ObjectId ist neuer Timer '" . $Name . "'
return $ObjectId;
/** Quelle IPSInstaller (unzutreffenderweise Get_IdentByName: Ident aus Namen generieren) */
function Trim_Ident ($name) {
$ident = str_replace (' ', '', $name);
$ident = str_replace (array ('ö', 'ä', 'ü', 'Ö', 'Ä', 'Ü'), array ('oe', 'ae', 'ue', 'Oe', 'Ae', 'Ue'), $ident);
$ident = str_replace (array ('"', '\'', '%', '&', '(', ')', '=', '#', '<', '>', '|', '\\'), '', $ident);
$ident = str_replace (array (',', '.', ':', ';', '!', '?'), '', $ident);
$ident = str_replace (array ('+', '-', '/', '*'), '', $ident);
return $ident;
function UpdateObjectData ($ObjectId, $Position, $Icon = "") {
global $Msg;
$ObjectData = IPS_GetObject ($ObjectId);
$ObjectPath = IPS_GetLocation ($ObjectId);
if ($ObjectData['ObjectPosition'] <> $Position and $Position !== false) {
$Msg .= "Set ObjectPosition='$Position' for Object='$ObjectPath'
if ($ObjectData['ObjectIcon'] <> $Icon and $Icon !== false) {
$Msg .= "Set ObjectIcon='$Icon' for Object='$ObjectPath'
Achtung Falle !!
Wenn man ein auf einem Windows-PC ein für einen Linux-PC vorgesehenes Skript-File (*.sh) erstellt und dorthin überträgt, ist die Wahscheinlichkeit, dass es auf dem Linux-PC nicht korrekt abläuft, ziemlich hoch.
Grund: Die Text-Formate von Microsoft und dem Rest der Welt sind unterschiedlich und die Bash-Shell von Linux repariert das leider nicht!
Deshalb muß ein mit der obigen Methode übertragene Nicht-PHP-File auf dem Linux-PC „nachbearbeitet“ werden. Am besten geht das m.E. mit dem Tool Dos2Unix, das man sich folgendermaßen unter Linux installiert:
$ sudo apt-get install dos2unix
Auf neueren Windows-Systemen ist das Tool leider nicht installierbar.
Auch Text-Dateien (z.B. CRON-JOB Listen), die für Linux auf einem Windows-PC erstellt worden sind, müssen so nachbearbeitet werden!
Viel Spaß
Harald
Das folgende Skript z.B. mit dem Namen „WebhookBY.php“ im IP-Symcon Ordner unter /webfront/user abspeichern:
if (isset($_GET["RUNScriptID"])) {
$IPS_RunScriptID = (int)$_GET["RUNScriptID"];
IPS_RunScript($IPS_RunScriptID);
echo "Skript mit der ID ".$IPS_RunScriptID." wurde ausgeführt!";
elseif ((isset($_GET["SETVarID"])) AND (isset($_GET["SETVarVALUE"]))) {
$IPS_SETVarID = (int)$_GET["SETVarID"];
$IPS_SETVarVALUE = (int)$_GET["SETVarVALUE"];
SetValue($IPS_SETVarID, $IPS_SETVarVALUE);
echo "Die Variable mit der ID ".$IPS_SETVarID." wurde auf den Wert ".$IPS_SETVarVALUE." gesetzt!";
elseif (isset($_GET["GETVALVarID"])) {
$IPS_GETVarID = (int)$_GET["GETVALVarID"];
$GETWert = GetValue($IPS_GETVarID);
echo "Die Variable mit der ID ".$IPS_GETVarID." hat den Wert '".$GETWert."'!";
Dann kann man über die folgenden URLs ein Skript ausführen, den Wert einer existierenden Variable ändern oder den Wert einer Variable auslesen:
[b]
http://192.168.1.20:82/user/WebhookBY.php?SETVarID=22222&SETVarVALUE=25
[/b]
Variable mit ID 22222 auf Wert 25 setzen
[b]
http://192.168.1.20:82/user/WebhookBY.php?RUNScriptID=11111
[/b]
Skript mit der ID 11111 ausführen
[b]
http://192.168.1.20:82/user/WebhookBY.php?GETVALVarID=33333
[/b]
>> Wert der Variable 33333 auslesen
IP und PORT natürlich gegen die IP vom eigenen IPS-Server und dem zugehörigen WebFront Port austauschen.
$HEXwert = "FABF"; // HEX-Wert
$BINwert = CS_hex2bin($HEXwert);
echo "HEX = $HEXwert // Binär = $BINwert";
function CS_hex2bin($str) {
$build = '';
$build = decbin(hexdec($str));
$build = str_pad($build, 8,0, STR_PAD_LEFT);
return $build;
Funktion aus einem Skript vom User „Raketenschnecke“:
function RGB2HEX($r, $g=-1, $b=-1) {
if (is_array($r) && sizeof($r) == 3)
list($r, $g, $b) = $r;
$r = intval($r);
$g = intval($g);
$b = intval($b);
$r = dechex($r<0?0:($r>255?255:$r));
$g = dechex($g<0?0:($g>255?255:$g));
$b = dechex($b<0?0:($b>255?255:$b));
$color = (strlen($r) < 2?§\'0§\':§\'§\').$r;
$color .= (strlen($g) < 2?§\'0§\':§\'§\').$g;
$color .= (strlen($b) < 2?§\'0§\':§\'§\').$b;
return $color;
Dieses Skript loggt Variablenänderungen einer Boolean-Variable in einer HTMLBox. Damit kann man z.B. die letzten 30 Tür-/Fenster-Öffnungen übersichtlich im WebFront oder der mobilen App darstellen.
> Das Skript stammt nicht von mir! Ich habe es nur ein wenig erweitert und die Benutzung vereinfacht. Leider weiß ich nicht wer der ursprüngliche Author ist. Sollte er noch aktiv sein, kann er sich gerne bei mir melden und ich trage das hier noch nach.
// Dieses Skript an einer zentralen Stelle ablegen und beliebig viele Ereignisse (Trigger-Events) hinzufügen.
// Das Ereignis muss auf Variablenänderung einer BOOLEAN-Variable reagieren.
// Nach der 1. Variablenänderung (der Quell/Bool-Variable) werden unterhalb der "Quell"-Variable (Bool) 2 neue Variablen
// angelegt. Eine Temp-Var (String) als Zwischenspeicher und eine Ausgabe-Var (String mit ~HTMLBox), welche
// dann ins WebFront verlinkt werden muss und das Log beinhaltet.
// *** KONFIGURATION: ***//
$LimitLogEintraege = 30; // Nach erreichen dieses Limits werden die ältesten Einträge durch neue abgelöst.
/***** AB HIER NICHTS MEHR ÄNDERN *******************************************************************/
MessageLog(IPS_GetName($_IPS['VARIABLE']). " - " .boolString($_IPS['VALUE']), $LimitLogEintraege);
function MessageLog($zeile, $LimitLogEintraege) {
$TempVar = CreateVariableByName($_IPS['VARIABLE'], "Temp-Var", 3, "", "");
$AusgabeVar = CreateVariableByName($_IPS['VARIABLE'], "MessageLog", 3, "~HTMLBox", "");
//CEL holen
$cel = array();
$cel = unserialize(GetValue($TempVar));
//Wurden Meldungen rückgelesen?
if (!is_array($cel)) {
//Leeres Array anlegen
$cel = array();
//Eintrag anfügen
array_unshift($cel,date("d.m. H:i")." || ".$zeile);
//Mehr als X Einträge
if (count($cel) > $LimitLogEintraege) {
//ältesten Eintrag löschen
$cel = array_slice($cel,0,-1);
//für Designer aufbereiten
$cel_liste = "";
foreach ($cel as $cel_entry){
$cel_liste .= $cel_entry."<br>";
SetValue($AusgabeVar, $cel_liste);
// Designer Ende
//CEL speichern
SetValue($TempVar, serialize($cel));
function boolString($bValue = false) { // returns string
return ($bValue ? 'geschlossen' : 'geöffnet');
function CreateVariableByName($ParentID, $VarName, $VarTyp, $VarProfile = "", $VarActionScript = "") {
$VarID = @IPS_GetVariableIDByName($VarName, $ParentID);
if($VarID === false) {
$VarID = IPS_CreateVariable($VarTyp);
IPS_SetParent($VarID, $ParentID);
IPS_SetName($VarID, $VarName);
IPS_SetInfo($VarID, "This variable was created by script #".$_IPS["SELF"]);
if($VarProfile !== "") {
IPS_SetVariableCustomProfile($VarID, $VarProfile);
if($VarActionScript !== "") {
IPS_SetVariableCustomAction($VarID, $VarActionScript);
return $VarID;
// Analysiert die Baumstruktur ab dem IP-S Objekt mit folgender ObjektID:
$ObjID = 40328 /*[Haus\EG\Rolläden\Küche]*/ ;
* @file ObjektbaumListe.ips.php
* @version 06.09.16 18:08, 27.09.16 20:34
* Ident: -
* Präsentiert die Baumstruktur ab dem angegebenen IP-S Objekt
* Version <br/>
// lokale Bedingungen setzen ($lSem)
$Sem = 0;
define ("ListeTyp", pow (2, $Sem ++ )); // ListeObjektTyp
define ("ListeIdent", pow (2, $Sem ++ )); // Liste den Ident
define ("kurzEinzug", pow (2, $Sem ++ )); // der Einzug für jede Ebene wird verkürzt
define ("Target", pow (2, $Sem ++ )); // Bei Links wird das Ziel gelistet
define ("WertStattIdent", pow (2, $Sem ++ )); // Liste den Wert anstelle des Idents
$lSem = 0 + ListeTyp + kurzEinzug + ListeIdent ; // lokale Semaphoren
$IdentTab = 38; // Tabulator für die Ident/Vanlue-Darstellung
if ($lSem & WertStattIdent) // wenn Werte
$lSem &= ~ListeIdent; // dann keine Idents
print("Objektbaum ab " . $ObjID . ' /' . IPS_GetLocation ($ObjID) . "
print("ObjektID Standort/ggf. Typ:/Objekt ");
if ($lSem & ListeIdent) {
print("ggf. {Ident}");
} else {
if ($lSem & WertStattIdent) {
print("ggf. [Value]");
print("
PrintBaum ($ObjID);
function PrintBaum ($ObjID) {
global $lSem, $IdentTab;
$Objekt = IPS_GetObject ($ObjID);
$ObjektTyp = array ('Kat', 'Ins', 'Var', 'Skr', 'Evt', 'Med', 'Lnk');
$Typ = $ObjektTyp[$Objekt['ObjectType']];
$Pfad = IPS_GetLocation ($ObjID);
$Len1 = '';
for ($i = 1; $i <= (strlen (IPS_GetLocation ($ObjID)) - strlen ($Objekt['ObjectName'])); $i ++ ) {
$Len1 .=' ';
if ($lSem & kurzEinzug) {
$Len1 = '';
$Ebenen = count (explode ('\\', IPS_GetLocation ($ObjID)));
for ($i = 1; $i <= ($Ebenen * 5); $i ++ ) {
$Len1 .=' ';
print( $ObjID . " " . $Len1);
if ($lSem & ListeTyp) {
print( $Typ . ':');
print( '/' . $Objekt['ObjectName']);
if ($lSem & Target) {
if ($Typ == 'Lnk')
print( " --> " . IPS_GetLink ($ObjID)['TargetID'] . ' ' . IPS_GetLocation (IPS_GetLink ($ObjID)['TargetID']));
$Len2 = '' . " "; // Mindest-Abstand
for ($i = strlen ($Len1) + strlen ($Objekt['ObjectName']); $i <= $IdentTab; $i ++ ) {
$Len2 .=' ';
print($Len2 . "{" . IPS_GetObject ($ObjID)['ObjectIdent'] . "}");
} else {
if ($lSem & WertStattIdent) { // erst abfragen ob Variable
if ($Typ == 'Var') {
for ($i = strlen ($Len1) + strlen ($Objekt['ObjectName']); $i <= $IdentTab; $i ++) {
$Len2 .=' ';
print($Len2 . "[");
switch (IPS_GetVariable ($ObjID)['VariableValue']['ValueType']):
case 0:
if (@GetValue ($ObjID)) {
print('TRUE');
} else {
print('FALSE');
break;
case 1:
print((@GetValue ($ObjID)));
break;
case 2:
case 3:
print( @GetValueFormatted ($ObjID));
break;
default:
endswitch;
print( "]");
print("
if ($Objekt['HasChildren']) { // muß dann erst sortiert werden
$ReiheN = array (); // ObjID => Name
$ReiheP = array (); // ObjID => Position
$ReiheZ = array (); // Nr => ObjID
foreach ($Objekt['ChildrenIDs'] as $i => $ChID) {
$ReiheN[$ChID] = IPS_GetObject ($ChID)['ObjectName'];
$ReiheP[$ChID] = IPS_GetObject ($ChID)['ObjectPosition'];
asort ($ReiheN, SORT_STRING); // falls nicht einsortiert, entscheidet der Name über die Reihenfolge
foreach ($ReiheN as $ChID => $Name) {
$ReiheZ[] = $ChID;
// weil PHP keine "Stabile" Sortierverfahren anbietet, brauche ich ein eigenes Verfahren,
// nehme BubbleSort aus https://en.wikibooks.org/wiki/Algorithm_Implementation/Sorting/Bubble_sort#PHP
$size = count ($ReiheN);
for ($i = 0; $i < $size; $i ++) {
for ($j = 0; $j < $size - 1 - $i; $j ++) {
if ($ReiheP[$ReiheZ[$j + 1]] < $ReiheP[$ReiheZ[$j]])
list($ReiheZ[$j], $ReiheZ[$j + 1]) = array ($ReiheZ[$j + 1], $ReiheZ[$j]);
foreach ($ReiheZ as $i => $ChID) {
PrintBaum ($ChID); // rekursiver Aufruf
Mit der Einstellung
in Zeile 25 werden die Idents der gelisteten Objekte mit angezeigt:
Objektbaum ab 40328 /Haus\EG\Rolläden\Küche
ObjektID Standort/ggf. Typ:/Objekt ggf. {Ident}
40328 Ins:/Küche {NEQ0111912_01_HMLCBl1FM}
53202 Var:/DIRECTION {DIRECTION}
20708 Var:/INHIBIT {INHIBIT}
42699 Var:/Rolladen Küche {LEVEL}
51589 Var:/WORKING {WORKING}
Mit der Einstellung
$lSem = 0 + ListeTyp + kurzEinzug + WertStattIdent ;
werden statt der Idents die Werte der Objekte mit angezeigt:
ObjektID Standort/ggf. Typ:/Objekt ggf. [Value]
40328 Ins:/Küche
53202 Var:/DIRECTION [0]
20708 Var:/INHIBIT [FALSE]
42699 Var:/Rolladen Küche [Geschlossen]
51589 Var:/WORKING [FALSE]
Mit der Einstellung
$lSem = 0 + ListeTyp + kurzEinzug + Target;
wird bei Links das Ziel gelistet:
Objektbaum ab 41767 /OBJVIS\WFC:Svr1\Rollos_Akt\Markisen
41767 Ins:/Markisen
42655 Lnk:/Dachfenster --> 14752 Melder\Rolläden und Markisen\Markisen\Dachfenster
49687 Lnk:/Dachbalkon --> 16239 Melder\Rolläden und Markisen\Markisen\Dachbalkon
58981 Lnk:/Holzterasse --> 44984 Melder\Rolläden und Markisen\Markisen\Holzterasse
Viel Spaß
Harald
