Hallo fileicht hat wer eine Lösung bekomme immer eine Fehlermeldung (IPS läuft unter windows 10):
Im modul.php wurde der pfad geändert:
declare(strict_types=1);
require_once __DIR__ . '/../libs/common.php'; // globale Funktionen
class Speedtest extends IPSModule
use SpeedtestCommon;
public function Create()
parent::Create();
$this->RegisterPropertyBoolean('module_disable', false);
$this->RegisterPropertyInteger('update_interval', '0');
$this->RegisterPropertyInteger('preferred_server', '0');
$this->RegisterPropertyString('exclude_server', '');
$this->RegisterPropertyBoolean('no_pre_allocate', true);
$this->RegisterTimer('UpdateData', 0, 'Speedtest_UpdateData(' . $this->InstanceID . ');');
$this->CreateVarProfile('Speedtest.ms', VARIABLETYPE_FLOAT, ' ms', 0, 0, 0, 0, '');
$this->CreateVarProfile('Speedtest.MBits', VARIABLETYPE_FLOAT, ' MBit/s', 0, 0, 0, 1, '');
private function CheckPrerequisites()
$s = '';
$data = exec('C:\ProgramData\Symcon\speedtest-cli --version 2>&1', $output, $exitcode);
if ($exitcode != 0) {
$s = $this->Translate('The following system prerequisites are missing') . ': speedtest-cli';
return $s;
public function ApplyChanges()
parent::ApplyChanges();
$vpos = 0;
$this->MaintainVariable('ISP', $this->Translate('Internet-Provider'), VARIABLETYPE_STRING, '', $vpos++, true);
$this->MaintainVariable('IP', $this->Translate('external IP'), VARIABLETYPE_STRING, '', $vpos++, true);
$this->MaintainVariable('Server', $this->Translate('Server'), VARIABLETYPE_STRING, '', $vpos++, true);
$this->MaintainVariable('Ping', $this->Translate('Ping'), VARIABLETYPE_FLOAT, 'Speedtest.ms', $vpos++, true);
$this->MaintainVariable('Upload', $this->Translate('Upload'), VARIABLETYPE_FLOAT, 'Speedtest.MBits', $vpos++, true);
$this->MaintainVariable('Download', $this->Translate('Download'), VARIABLETYPE_FLOAT, 'Speedtest.MBits', $vpos++, true);
$this->MaintainVariable('LastTest', $this->Translate('Last test'), VARIABLETYPE_INTEGER, '~UnixTimestamp', $vpos++, true);
$s = $this->CheckPrerequisites();
if ($s != '') {
$this->SetStatus(IS_INVALIDPREREQUISITES);
return;
$module_disable = $this->ReadPropertyBoolean('module_disable');
if ($module_disable) {
$this->SetTimerInterval('UpdateData', 0);
$this->SetStatus(IS_INACTIVE);
return;
$this->SetStatus(IS_ACTIVE);
$this->SetUpdateInterval();
public function GetConfigurationForm()
$formElements = [];
if ($s == '') {
$formElements[] = ['type' => 'CheckBox', 'name' => 'module_disable', 'caption' => 'Instance is disabled'];
$options = [];
$options[] = ['label' => $this->Translate('automatically select'), 'value' => 0];
$data = exec('speedtest-cli --list 2>&1', $output, $exitcode);
$n = 0;
foreach ($output as $line) {
if (preg_match('/[ ]*([0-9]*)\)\s([^[]*)/', $line, $r)) {
if ($r[1] > 0) {
$options[] = ['label' => $r[2], 'value' => $r[1]];
if ($n++ == 100) {
break;
$formElements[] = ['type' => 'Select', 'name' => 'preferred_server', 'caption' => 'Preferred server', 'options' => $options];
$formElements[] = ['type' => 'Label', 'label' => 'Excluded server (comma-separated)'];
$formElements[] = ['type' => 'ValidationTextBox', 'name' => 'exclude_server', 'caption' => 'List'];
$formElements[] = ['type' => 'CheckBox', 'name' => 'no_pre_allocate', 'caption' => 'Set option --no_pre_allocate'];
$formElements[] = ['type' => 'Label', 'label' => 'Update data every X minutes'];
$formElements[] = ['type' => 'NumberSpinner', 'name' => 'update_interval', 'caption' => 'Minutes'];
} else {
$formElements[] = ['type' => 'Label', 'label' => $s];
$formActions = [];
if ($s == '') {
$formActions[] = ['type' => 'Label', 'label' => 'Updating the data takes up to 1 minute'];
$formActions[] = ['type' => 'Button', 'label' => 'Update data', 'onClick' => 'Speedtest_UpdateData($id);'];
if (IPS_GetKernelVersion() < 5.2) {
$formActions[] = ['type' => 'Label', 'label' => '____________________________________________________________________________________________________'];
$formActions[] = [
'type' => 'Button',
'caption' => 'Module description',
'onClick' => 'echo "https://github.com/demel42/IPSymconSpeedtest/blob/master/README.md";'
$formStatus = [];
$formStatus[] = ['code' => IS_CREATING, 'icon' => 'inactive', 'caption' => 'Instance getting created'];
$formStatus[] = ['code' => IS_ACTIVE, 'icon' => 'active', 'caption' => 'Instance is active'];
$formStatus[] = ['code' => IS_DELETING, 'icon' => 'inactive', 'caption' => 'Instance is deleted'];
$formStatus[] = ['code' => IS_INACTIVE, 'icon' => 'inactive', 'caption' => 'Instance is inactive'];
$formStatus[] = ['code' => IS_NOTCREATED, 'icon' => 'inactive', 'caption' => 'Instance is not created'];
$formStatus[] = ['code' => IS_INVALIDPREREQUISITES, 'icon' => 'error', 'caption' => 'Instance is inactive (invalid preconditions)'];
return json_encode(['elements' => $formElements, 'actions' => $formActions, 'status' => $formStatus]);
protected function SetUpdateInterval()
$min = $this->ReadPropertyInteger('update_interval');
$msec = $min > 0 ? $min * 1000 * 60 : 0;
$this->SetTimerInterval('UpdateData', $msec);
public function UpdateData()
$preferred_server = $this->ReadPropertyInteger('preferred_server');
$exclude_server = $this->ReadPropertyString('exclude_server');
$this->PerformTest($preferred_server, $exclude_server);
public function PerformTest(int $preferred_server, string $exclude_server)
if ($this->GetStatus() == IS_INACTIVE) {
$this->SendDebug(__FUNCTION__, 'instance is inactive, skip', 0);
return;
$cmd = 'speedtest-cli --json';
// use https instead of http
// $cmd .= ' --secure';
// Do not pre allocate upload data. Pre allocation is
// enabled by default to improve upload performance. To
// support systems with insufficient memory, use this
// option to avoid a MemoryError
$no_pre_allocate = $this->ReadPropertyBoolean('no_pre_allocate');
if ($no_pre_allocate) {
$cmd .= ' --no-pre-allocate';
// Specify a server ID to test against. Can be supplied
// multiple times
if ($preferred_server > 0) {
$cmd .= ' --server=' . $preferred_server;
// Exclude a server from selection. Can be supplied
// multiple times
if ($exclude_server != '') {
$serverV = explode(',', $exclude_server);
foreach ($serverV as $server) {
$cmd .= ' --exclude=' . $server;
$cmd .= ' 2>&1';
$this->SendDebug(__FUNCTION__, 'cmd="' . $cmd . '"', 0);
$time_start = microtime(true);
$data = exec($cmd, $output, $exitcode);
$duration = floor((microtime(true) - $time_start) * 100) / 100;
if ($exitcode) {
$ok = false;
$err = $data;
} else {
$ok = true;
$err = '';
if (preg_match('/speedtest-cli: error:\s(.*?)$/', $data, $r)) {
$err = $r[1];
$ok = false;
$this->SendDebug(__FUNCTION__, 'duration=' . $duration . ', exitcode=' . $exitcode . ', status=' . ($ok ? 'ok' : 'fail') . ', err=' . $err, 0);
$isp = '';
$ip = '';
$sponsor = '';
$id = '';
$ping = '';
$download = '';
$upload = '';
if ($ok) {
$this->SendDebug(__FUNCTION__, 'data=' . $data, 0);
$jdata = json_decode($data, true);
if ($jdata == '') {
$ok = false;
$err = 'malformed data';
} else {
$this->SendDebug(__FUNCTION__, 'jdata=' . print_r($jdata, true), 0);
if (isset($jdata['client']['isp'])) {
$isp = $jdata['client']['isp'];
if (isset($jdata['client']['ip'])) {
$ip = $jdata['client']['ip'];
if (isset($jdata['server']['sponsor'])) {
$sponsor = $jdata['server']['sponsor'];
if (isset($jdata['server']['id'])) {
$id = $jdata['server']['id'];
if (isset($jdata['ping'])) {
$ping = $jdata['ping'];
if (isset($jdata['download'])) {
// Umrechnung von Bit auf MBit mit 2 Nachkommastellen
$download = floor($jdata['download'] / (1024 * 1024) * 10000) / 10000;
if (isset($jdata['upload'])) {
$upload = floor($jdata['upload'] / (1024 * 1024) * 10000) / 10000;
$this->SendDebug(__FUNCTION__, ' ... isp=' . $isp . ', ip=' . $ip . ', sponsor=' . $sponsor . ', id=' . $id . ', ping=' . $ping . ', download=' . $download . ', upload=' . $upload, 0);
if ($ok) {
IPS_LogMessage(__CLASS__ . '::' . __FUNCTION__, 'server=' . $id . ') ' . $sponsor . ', duration=' . $duration . ', status=' . ($ok ? 'ok' : 'fail'));
$this->SetValue('ISP', $isp);
$this->SetValue('IP', $ip);
$this->SetValue('Server', $sponsor);
$this->SetValue('Ping', $ping);
$this->SetValue('Upload', $upload);
$this->SetValue('Download', $download);
} else {
$msg = 'failed: exitcode=' . $exitcode . ', err=' . $err;
$this->LogMessage(__CLASS__ . '::' . __FUNCTION__ . ': ' . $msg, KL_WARNING);
$this->SendDebug(__FUNCTION__, $msg, 0);
$this->SetValue('LastTest', time());
gruß Stefan
