danke, da hatte ich noch nicht nachgesehen.
also hier die Logs zu oben:
08.12.2009 18:28:47.490 | 17696 | MESSAGE | Client Socket | Socket: Getrennt
08.12.2009 18:28:54.114 | 17696 | MESSAGE | Client Socket | Socket: Verbunden
08.12.2009 18:28:54.130 | 55989 | MESSAGE | VariableManager | [UVR1611\Sensor (1)] = 5,59999990463257
08.12.2009 18:28:54.130 | 50431 | MESSAGE | VariableManager | [UVR1611\Sensor (2)] = 24,6000003814697
08.12.2009 18:28:54.130 | 33247 | MESSAGE | VariableManager | [UVR1611\Sensor (3)] = 57,7999992370605
08.12.2009 18:28:54.130 | 18275 | MESSAGE | VariableManager | [UVR1611\Sensor (4)] = 38,4000015258789
08.12.2009 18:28:54.130 | 40959 | MESSAGE | VariableManager | [UVR1611\Sensor (5)] = 6,40000009536743
08.12.2009 18:28:54.130 | 18350 | DEBUG | VariableManager | [UVR1611\Sensor (6)] = 22,7999992370605
08.12.2009 18:28:54.130 | 48878 | MESSAGE | VariableManager | [UVR1611\Sensor (7)] = 22,5
08.12.2009 18:28:54.130 | 28878 | DEBUG | VariableManager | [UVR1611\Sensor (8)] = 27,6000003814697
08.12.2009 18:28:54.130 | 40049 | DEBUG | VariableManager | [UVR1611\Sensor (9)] = 30,2000007629395
08.12.2009 18:28:54.130 | 59803 | MESSAGE | VariableManager | [UVR1611\Sensor (10)] = 42,0999984741211
08.12.2009 18:28:54.130 | 49954 | DEBUG | VariableManager | [UVR1611\Sensor (11)] = 20
08.12.2009 18:28:54.130 | 46173 | MESSAGE | VariableManager | [UVR1611\Sensor (12)] = 37,5
08.12.2009 18:28:54.130 | 54943 | DEBUG | VariableManager | [UVR1611\Sensor (13)] = 0
08.12.2009 18:28:54.130 | 26474 | DEBUG | VariableManager | [UVR1611\Sensor (14)] = 0
08.12.2009 18:28:54.130 | 57494 | DEBUG | VariableManager | [UVR1611\Sensor (15)] = 0
08.12.2009 18:28:54.130 | 35300 | DEBUG | VariableManager | [UVR1611\Sensor (16)] = 0
08.12.2009 18:28:54.130 | 27228 | DEBUG | VariableManager | [UVR1611\Output (1)] = False
08.12.2009 18:28:54.130 | 14449 | DEBUG | VariableManager | [UVR1611\Output (2)] = True
08.12.2009 18:28:54.130 | 48531 | DEBUG | VariableManager | [UVR1611\Output (3)] = False
08.12.2009 18:28:54.130 | 49873 | DEBUG | VariableManager | [UVR1611\Output (4)] = False
08.12.2009 18:28:54.130 | 22626 | DEBUG | VariableManager | [UVR1611\Output (5)] = False
08.12.2009 18:28:54.130 | 35158 | DEBUG | VariableManager | [UVR1611\Output (6)] = False
08.12.2009 18:28:54.130 | 33362 | DEBUG | VariableManager | [UVR1611\Output (7)] = True
08.12.2009 18:28:54.130 | 10223 | DEBUG | VariableManager | [UVR1611\Output (8)] = False
08.12.2009 18:28:54.130 | 35308 | DEBUG | VariableManager | [UVR1611\Output (9)] = False
08.12.2009 18:28:54.130 | 18029 | DEBUG | VariableManager | [UVR1611\Output (10)] = False
08.12.2009 18:28:54.130 | 10503 | DEBUG | VariableManager | [UVR1611\Output (11)] = False
08.12.2009 18:28:54.130 | 20105 | DEBUG | VariableManager | [UVR1611\Output (12)] = False
08.12.2009 18:28:54.130 | 31069 | DEBUG | VariableManager | [UVR1611\Output (13)] = False
08.12.2009 18:28:54.130 | 55396 | DEBUG | VariableManager | [UVR1611\Engine Speed (1)] = -1
08.12.2009 18:28:54.130 | 35188 | DEBUG | VariableManager | [UVR1611\Engine Speed (2)] = -1
08.12.2009 18:28:54.130 | 22824 | DEBUG | VariableManager | [UVR1611\Engine Speed (3)] = -1
08.12.2009 18:28:54.130 | 26775 | DEBUG | VariableManager | [UVR1611\Engine Speed (4)] = -1
08.12.2009 18:28:54.130 | 31670 | DEBUG | VariableManager | [UVR1611\Heat Input Status (1)] = False
08.12.2009 18:28:54.130 | 41272 | DEBUG | VariableManager | [UVR1611\Heat Input Status (2)] = False
08.12.2009 18:28:54.130 | 27964 | DEBUG | VariableManager | [UVR1611\Current Heat Input (1)] = 0
08.12.2009 18:28:54.130 | 20703 | DEBUG | VariableManager | [UVR1611\Total Heat Input (1)] = 0
08.12.2009 18:28:54.130 | 54825 | DEBUG | VariableManager | [UVR1611\Current Heat Input (2)] = 0
08.12.2009 18:28:54.130 | 26223 | DEBUG | VariableManager | [UVR1611\Total Heat Input (2)] = 0
08.12.2009 18:54:57.962 | 17696 | MESSAGE | Client Socket | Socket: Verbunden
08.12.2009 18:54:57.962 | 55989 | MESSAGE | VariableManager | [UVR1611\Sensor (1)] = 5,40000009536743
08.12.2009 18:54:57.977 | 50431 | MESSAGE | VariableManager | [UVR1611\Sensor (2)] = 24,2999992370605
08.12.2009 18:54:57.977 | 33247 | MESSAGE | VariableManager | [UVR1611\Sensor (3)] = 57,5
08.12.2009 18:54:57.977 | 18275 | MESSAGE | VariableManager | [UVR1611\Sensor (4)] = 36,7999992370605
08.12.2009 18:54:57.977 | 40959 | DEBUG | VariableManager | [UVR1611\Sensor (5)] = 6,40000009536743
08.12.2009 18:54:57.977 | 18350 | MESSAGE | VariableManager | [UVR1611\Sensor (6)] = 22,7000007629395
08.12.2009 18:54:57.977 | 48878 | MESSAGE | VariableManager | [UVR1611\Sensor (7)] = 22,3999996185303
08.12.2009 18:54:57.977 | 28878 | MESSAGE | VariableManager | [UVR1611\Sensor (8)] = 27,7000007629395
08.12.2009 18:54:57.977 | 40049 | DEBUG | VariableManager | [UVR1611\Sensor (9)] = 30,2000007629395
08.12.2009 18:54:57.977 | 59803 | MESSAGE | VariableManager | [UVR1611\Sensor (10)] = 41,5
08.12.2009 18:54:57.977 | 49954 | DEBUG | VariableManager | [UVR1611\Sensor (11)] = 20
08.12.2009 18:54:57.977 | 46173 | MESSAGE | VariableManager | [UVR1611\Sensor (12)] = 36
08.12.2009 18:54:57.977 | 54943 | DEBUG | VariableManager | [UVR1611\Sensor (13)] = 0
08.12.2009 18:54:57.977 | 26474 | DEBUG | VariableManager | [UVR1611\Sensor (14)] = 0
08.12.2009 18:54:57.977 | 57494 | DEBUG | VariableManager | [UVR1611\Sensor (15)] = 0
08.12.2009 18:54:57.977 | 35300 | DEBUG | VariableManager | [UVR1611\Sensor (16)] = 0
08.12.2009 18:54:57.977 | 27228 | DEBUG | VariableManager | [UVR1611\Output (1)] = False
08.12.2009 18:54:57.977 | 14449 | DEBUG | VariableManager | [UVR1611\Output (2)] = True
08.12.2009 18:54:57.977 | 48531 | DEBUG | VariableManager | [UVR1611\Output (3)] = False
08.12.2009 18:54:57.977 | 49873 | DEBUG | VariableManager | [UVR1611\Output (4)] = False
08.12.2009 18:54:57.977 | 22626 | DEBUG | VariableManager | [UVR1611\Output (5)] = False
08.12.2009 18:54:57.977 | 35158 | DEBUG | VariableManager | [UVR1611\Output (6)] = False
08.12.2009 18:54:57.977 | 33362 | DEBUG | VariableManager | [UVR1611\Output (7)] = True
08.12.2009 18:54:57.977 | 10223 | DEBUG | VariableManager | [UVR1611\Output (8)] = False
08.12.2009 18:54:57.977 | 35308 | DEBUG | VariableManager | [UVR1611\Output (9)] = False
08.12.2009 18:54:57.977 | 18029 | DEBUG | VariableManager | [UVR1611\Output (10)] = False
08.12.2009 18:54:57.977 | 10503 | DEBUG | VariableManager | [UVR1611\Output (11)] = False
08.12.2009 18:54:57.977 | 20105 | DEBUG | VariableManager | [UVR1611\Output (12)] = False
08.12.2009 18:54:57.977 | 31069 | DEBUG | VariableManager | [UVR1611\Output (13)] = False
08.12.2009 18:54:57.977 | 55396 | DEBUG | VariableManager | [UVR1611\Engine Speed (1)] = -1
08.12.2009 18:54:57.977 | 35188 | DEBUG | VariableManager | [UVR1611\Engine Speed (2)] = -1
08.12.2009 18:54:57.977 | 22824 | DEBUG | VariableManager | [UVR1611\Engine Speed (3)] = -1
08.12.2009 18:54:57.977 | 26775 | DEBUG | VariableManager | [UVR1611\Engine Speed (4)] = -1
08.12.2009 18:54:57.977 | 31670 | DEBUG | VariableManager | [UVR1611\Heat Input Status (1)] = False
08.12.2009 18:54:57.977 | 41272 | DEBUG | VariableManager | [UVR1611\Heat Input Status (2)] = False
08.12.2009 18:54:57.977 | 27964 | DEBUG | VariableManager | [UVR1611\Current Heat Input (1)] = 0
08.12.2009 18:54:57.977 | 20703 | DEBUG | VariableManager | [UVR1611\Total Heat Input (1)] = 0
08.12.2009 18:54:57.977 | 54825 | DEBUG | VariableManager | [UVR1611\Current Heat Input (2)] = 0
08.12.2009 18:54:57.977 | 26223 | DEBUG | VariableManager | [UVR1611\Total Heat Input (2)] = 0
