// test program rs485
// DRS110M
// Translated from Python; thanks to Marmangra ( Stromzähler mit RS485 - Seite 2)
// Thanks to Frank van de Pol: Arduino/drs110m_test at master · fvdpol/Arduino · GitHub
#define SERIAL_BAUD 57600
int tx_sel = 2; // pin to enable MAX485 output
String SerialID = "000000000000";
String Password = "00000000";
char c_init[] = {'/', '?', '!', '\r', '
', '\0'}; //Get serial nr
char c_startread[] = {'/', '?', 'S', 'E', 'R', 'I', 'A', 'L', '!', '\r', '
', '\0'}; //RETURN: YTL: meterID (12 cijfers)
char c_ack[] = {0x06, 0x30, ':', 0x31, 0x0D, 0x0A, '\r', '
', '\0'}; //Programming mode //RETURN: PO: xxxxxxxx
char c_login[] = {0x01, 'P', '1', 0x02, '(', 'P', 'A', 'S', 'S', ')', 0x03, 0x61, '\r', '
', '\0'}; //RETURN: nothing
char c_logout[] = {0x01, 'B', '0', 0x03, 0x71, '/', '?', '!', '\r', '
', '\0'};
char c_voltage[] = {0x01, 'R', '1', 0x02, '0', '0', '0', '0', '0', '0', '0', '0', '(', ')', 0x03, 0x63, '\0'};
char c_amps[] = {0x01, 'R', '1', 0x02, '0', '0', '0', '0', '0', '0', '0', '1', '(', ')', 0x03, 0x62, '\0'};
char c_freq[] = {0x01, 'R', '1', 0x02, '0', '0', '0', '0', '0', '0', '0', '2', '(', ')', 0x03, 0x61, '\0'};
char c_Pwerkelijk[] = {0x01, 'R', '1', 0x02, '0', '0', '0', '0', '0', '0', '0', '3', '(', ')', 0x03, 0x60, '\0'};
char c_Pblind[] = {0x01, 'R', '1', 0x02, '0', '0', '0', '0', '0', '0', '0', '4', '(', ')', 0x03, 0x67, '\0'};
char c_Pschijn[] = {0x01, 'R', '1', 0x02, '0', '0', '0', '0', '0', '0', '0', '5', '(', ')', 0x03, 0x66, '\0'};
char c_cosphi[] = {0x01, 'R', '1', 0x02, '0', '0', '0', '0', '0', '0', '0', '6', '(', ')', 0x03, 0x65, '\0'};
char c_standused1a[] = {0x01, 'R', '1', 0x02, '0', '0', '0', '0', '0', '0', '1', '0', '(', ')', 0x03, 0x62, '\0'};
char c_standused1b[] = {0x01, 'R', '1', 0x02, '0', '0', '0', '0', '0', '0', '1', '1', '(', ')', 0x03, 0x63, '\0'};
char c_standsenda[] = {0x01, 'R', '1', 0x02, '0', '0', '0', '0', '0', '0', '2', '0', '(', ')', 0x03, 0x61, '\0'};
char c_standsendb[] = {0x01, 'R', '1', 0x02, '0', '0', '0', '0', '0', '0', '2', '1', '(', ')', 0x03, 0x60, '\0'};
char c_tijddatum[] = {0x01, 'R', '1', 0x02, '0', '0', '0', '0', '0', '0', '3', '1', '(', ')', 0x03, 0x61, '\0'};
char c_temp[] = {0x01, 'R', '1', 0x02, '0', '0', '0', '0', '0', '0', '3', '2', '(', ')', 0x03, 0x62, '\0'};
char c_serialnr[] = {0x01, 'R', '1', 0x02, '0', '0', '0', '0', '0', '0', '3', '4', '(', ')', 0x03, 0x64, '\0'};
char c_baudrate[] = {0x01, 'R', '1', 0x02, '0', '0', '0', '0', '0', '0', '3', '5', '(', ')', 0x03, 0x65, '\0'};
char c_meterid[] = {0x01, 'R', '1', 0x02, '0', '0', '0', '0', '0', '0', '3', '6', '(', ')', 0x03, 0x66, '\0'};
String tmpval;
struct DRSDATA {
String Serialnr;
String MeterID;
String Unknown;
float Voltage;
float Amps;
float Freq;
float Cosphi;
int P_Werkelijk;
int P_Blind;
int P_Schijn;
float KWH_Verbruik;
float KWH_Verbruik2;
float KWH_Geleverd;
float KWH_Geleverd2;
float Temp;
String TimeDate;
float Baudrate;
DRSDATA DRSdata;
void setup() {
Serial.begin(SERIAL_BAUD);
pinMode(tx_sel, OUTPUT);
digitalWrite(tx_sel, LOW);
Serial3.begin(9600,SERIAL_7E1);
byte CreateSendString(char value[]){
clearbuffer();
digitalWrite(tx_sel, HIGH);
delay(1);
String retString = value;
retString.replace("PASS", Password);
retString.replace("SERIAL", SerialID);
Serial3.print(retString);
Serial3.flush();
delay(1);
delay(150);
return ReadSerial();
byte ReadSerial() {
String ReadedLine = "";
char MyChar[2]{0, '\0'};
while (Serial3.available()) {
MyChar[0] = Serial3.read();
ReadedLine += MyChar;
if (ReadedLine.startsWith("/YTL:")) { //Meter Serialnr
DRSdata.Serialnr = ReadedLine.substring(5,17);
Serial.println("Serialnr: " + DRSdata.Serialnr);
return 1;
else if (ReadedLine.startsWith("P0") && ReadedLine.endsWith("`")) { //UNKNOWN
DRSdata.Unknown = ReadedLine.substring(4,11);
Serial.println("UnKnown: " + DRSdata.Unknown);
return 1;
else if (extractIt(ReadedLine, "00000000(")) { //VOLTAGE
DRSdata.Voltage = tmpval.toFloat() / 10;
Serial.println("Voltage: " + String(DRSdata.Voltage));
return 1;
else if (extractIt(ReadedLine, "00000001(")) { //AMPS
DRSdata.Amps = tmpval.toFloat() / 10;
Serial.println("Amps: " + String(DRSdata.Amps));
return 1;
else if (extractIt(ReadedLine, "00000002(")) { //FREQ
DRSdata.Freq = tmpval.toFloat() / 10;
Serial.println("Freq: " + String(DRSdata.Freq));
return 1;
else if (extractIt(ReadedLine, "00000003(")) { //Werkelijk vermogen
DRSdata.P_Werkelijk = tmpval.toFloat() * 10;
Serial.println("Werkelijk vermogen: " + String(DRSdata.P_Werkelijk));
return 1;
else if (extractIt(ReadedLine, "00000004(")) { //Werkelijk vermogen
DRSdata.P_Blind = tmpval.toFloat() * 10;
Serial.println("Blind vermogen: " + String(DRSdata.P_Blind));
return 1;
else if (extractIt(ReadedLine, "00000005(")) { //Schijn vermogen
DRSdata.P_Schijn = tmpval.toFloat() * 10;
Serial.println("Schijn vermogen: " + String(DRSdata.P_Schijn));
return 1;
else if (extractIt(ReadedLine, "00000006(")) { //CosPhi
DRSdata.Cosphi = tmpval.toFloat() / 1000 ;
Serial.println("CosPhi: " + String(DRSdata.Cosphi));
return 1;
else if (extractIt(ReadedLine, "00000010(")) { //Tellerstand 1 (Verbruik)
DRSdata.KWH_Verbruik = tmpval.toFloat() / 1000 ;
Serial.println("Verbruikte KWH (1): " + String(DRSdata.KWH_Verbruik));
return 1;
else if (extractIt(ReadedLine, "00000011(")) { //Tellerstand 1 (Kopie)
DRSdata.KWH_Verbruik2 = tmpval.toFloat() / 1000 ;
Serial.println("Verbruikte KWH (2): " + String(DRSdata.KWH_Verbruik2));
return 1;
else if (extractIt(ReadedLine, "00000020(")) { //Tellerstand 2 (Teruggeleverd)
DRSdata.KWH_Geleverd = tmpval.toFloat() / 1000 ;
Serial.println("Geleverde KWH: " + String(DRSdata.KWH_Geleverd));
return 1;
else if (extractIt(ReadedLine, "00000021(")) { //Tellerstand 2 (Kopie)
DRSdata.KWH_Geleverd2 = tmpval.toFloat() / 1000 ;
Serial.println("Geleverde KWH2: " + String(DRSdata.KWH_Geleverd2));
return 1;
else if (extractIt(ReadedLine, "00000031(")) { //TijdDatum
DRSdata.TimeDate = tmpval;
Serial.println("TijdDatum: " + String(DRSdata.TimeDate));
return 1;
else if (extractIt(ReadedLine, "00000032(")) { //Temp
DRSdata.Temp = tmpval.toFloat() ;
Serial.println("Temperatuur: " + String(DRSdata.Temp));
return 1;
else if (extractIt(ReadedLine, "00000034(")) { //Serialnr
DRSdata.Serialnr = tmpval ;
Serial.println("Serialnr: " + String(DRSdata.Serialnr));
return 1;
else if (extractIt(ReadedLine, "00000035(")) { //Baudrate
DRSdata.Baudrate = tmpval.toFloat() ;
Serial.println("BaudRate: " + String(DRSdata.Baudrate));
return 1;
else if (extractIt(ReadedLine, "00000036(")) { //MeterID
DRSdata.MeterID = tmpval ;
Serial.println("MeterID: " + String(DRSdata.MeterID));
return 1;
else {
Serial.println(ReadedLine);
return 0;
bool extractIt(String StringIn, String SearchFor) {
if (StringIn.substring(1,10) == SearchFor) { //AMPS
int zoek = findChar(StringIn, ')', 10);
if (zoek > 0) {
tmpval = StringIn.substring(10, zoek);
return true;
return false;
static void handleInput (char c) {
switch (c) {
case 'd':
char c = Serial3.read();
Serial.print("RX: 0x");
Serial.print(c, HEX);
if (c>=32) {
Serial.print(" '");
Serial.print(char(c));
Serial.print("'");
Serial.println();
case '1':
byte ret;
Serial.println(F("Test Msg 1 - check Serial ID"));
ret = CreateSendString(c_startread);
ret += CreateSendString(c_ack);
ret += CreateSendString(c_login);
ret += CreateSendString(c_voltage);
ret += CreateSendString(c_amps);
ret += CreateSendString(c_freq);
ret += CreateSendString(c_cosphi);
ret += CreateSendString(c_standused1a);
ret += CreateSendString(c_standused1b);
ret += CreateSendString(c_standsenda);
ret += CreateSendString(c_standsendb);
ret += CreateSendString(c_tijddatum);
ret += CreateSendString(c_temp);
ret += CreateSendString(c_baudrate);
ret += CreateSendString(c_meterid);
ret += CreateSendString(c_Pwerkelijk);
ret += CreateSendString(c_Pblind);
ret += CreateSendString(c_Pschijn);
ret += CreateSendString(c_logout);
Serial.println(ret);
break;
void loop() {
while (Serial.available())
handleInput(Serial.read());
void clearbuffer() {
char c;
c = Serial3.read();
int findChar(String StringIN, char ChartoFind, byte StartPos) {
char myChar;
for (int i = StartPos; i < StringIN.length(); i++) {
myChar = StringIN.charAt(i);
if (myChar == ChartoFind) {
return i;
return -1;
(because there is a bug in the DRS110M meter, I had to change the time / date of the meter (between 0:00 and 1:00, the meter is reading out WATT values between 0:00 and 1:00, but doesn’t change / count to the meter total value)
I’ve changed the code, now you can read and write (time and date) to the meter… other changes are easy to add, because the CRC function is included.
// test program rs485 for Arduino
// DRS110M
', '\0'};
char w_tijddatum[] = {0x01, 'W', '1', 0x02, '0', '0', '0', '0', '0', '0', '3', '1', '(', 'D', 'A', 'T', 'E', '0', '0', '0', '2', 'T', 'I', 'M', 'E','0' ,'0', ')', 0x03, 111, '\0'};
String tmpval;
struct DRSDATA {
String Serialnr;
String MeterID;
String Unknown;
float Voltage;
float Amps;
float Freq;
float Cosphi;
int P_Werkelijk;
int P_Blind;
int P_Schijn;
float KWH_Verbruik;
float KWH_Geleverd;
float Temp;
String TimeDate;
float Baudrate;
DRSDATA DRSdata;
void setup() {
Serial.println("Press 1 <ENTER> to readout the DRS meter");
Serial.println("Press 2 <ENTER> to write a new date / time into the meter");
void WriteTimeDate(String newTime, String newDate) {
Serial.println("Writing Date: " + newTime + " / Writing Time: " + newDate);
byte ret = CreateSendString(c_startread);
clearbuffer();
delay(1);
String toSend = w_tijddatum;
toSend.replace("TIME00", newTime);
toSend.replace("DATE00", newDate);
toSend.setCharAt(29, CreateCRC(toSend)); //29 is the CRC Char POS!
Serial3.print(toSend);
Serial3.flush();
delay(2);
delay(300);
Serial.println("New Date/Time Written!: " + DRSdata.TimeDate);
clearbuffer();
delay(1);
Serial3.flush();
delay(1);
delay(150);
byte ReadSerial() {
return 1;
return 1;
return 1;
return 1;
return 1;
return 1;
return 1;
return 1;
return 1;
return 1;
return 1;
return 1;
return 1;
return 1;
return 1;
return 1;
return 1;
return 1;
else {
return 0;
if (zoek > 0) {
return true;
return false;
switch (c) {
case 'd':
if (c>=32) {
Serial.print(" '");
Serial.print("'");
Serial.println();
case '1':
byte ret;
break;
case '2':
Serial.println("Writing the time 13:25:00 and date 2015-02-12");
WriteTimeDate("132500", "150212"); //HHMMSS , YYMMDD
break;
void loop() {
char c;
c = Serial3.read();
char myChar;
return i;
return -1;
byte CreateCRC(String in) {
int len = in.length();
byte chr;
byte crc = 0;
for (int i = 1; i < len-1; i++) {
chr = in.charAt(i);
crc = crc xor chr;
return crc;
